Speakers
Old May 14, 2010 | 01:09 AM
disguy's Avatar
Speakers
How many speakers are in a 06 tl, and what are the sizes?
Old May 15, 2010 | 12:13 AM
07lightning's Avatar
6.5" in the doors and rear.
3.5" center speaker
2 tweeters in dash
8 inch sub in the back
7 speakers, 1 sub.
Old May 15, 2010 | 11:33 PM
A SiQ TL's Avatar
6.25" in the doors
had to do some "modification" to get my 6.5"s in the doors
Old May 16, 2010 | 03:55 PM
Deacon_01's Avatar
4th Gear
You guys ever replaced the factory speakers? Any lessons learned?
Old May 17, 2010 | 03:26 PM
vecterx's Avatar
I had all mine replaced in my 04TL. I have Polk audio 5.25" db5251 components installed all around. All I did was buy a 4 speaker brackets on eBay for $13 and thy sound amazing, no rattle, no static, no distortion. They getting 100rms watts
each. Just know that most after market speaker are 4 ohm so if you have a Bose head unit, they will not play with ur Bose radio. Also, you will have a very hard time trying to find a subwoofer to fit in that stock location, most 8" subs are too small and the 10" sub is too big. You're better off going with a subwoofer and box. I did my entire audio system over the the stock speakers have a funny shape to them so you either have to mod after market speakers to fit or get a speaker bracket.
Old May 24, 2010 | 11:26 PM
Joe1973's Avatar
I am replacing mine right now. I have already finished the passenger side. I put in Alpine spx17 pro 6.5 inch in the front and rear. I had to cut the hole to make it bigger in the doors, I also used 3/4 inch MDF as a bracket between the speaker and the door panel. I replaced the wiring and that was a pain in the ass! you have clips between the doors and I had to drill a hole through a none used portion of the clip. the tweeter was basicly a drop in, only needed miner modificatons and wiring took no time at all. I replaced the center with a S35 Boston caustics. I have two MTX T9500 15's for the trunk. should be done after this weekend!!
4drviper
Apr 23, 2025 07:13 PM
kb1rl
Sep 30, 2015 10:17 AM
polish_pat
Sep 25, 2015 12:24 PM
rboller
Sep 23, 2015 02:49 PM
