Sources for factory match cloth, trunk carpet and directions for A-pillar removal?
I was just wondering if anyone here knew a good source for a close factory match to the cloth that covers the A-pillars and/or had any experience removing them? I have an anthrocite TL with black leather interior. I'm looking to glass in some tweeter mounts and overcome some of my imaging and tonality issues with the factory locations. Also, a source for a close match for trunk carpet would be appreciated.
2004 SSM/EB/5AT/Navi/RSB
I'd be wary of messing with the A-pillars as they contain airbags. Maybe that's what you're asking about, but I thought I'd point it out just in case.
My installer is looking at an A-Pillar twet location as well...however, I had someone else who has build CES systems say that A-Pillar location for twets is a "popular mistake". Off topic, but what kind of system are you looking at installing?
Its good to be FRESH!!
dunno if you have it in your area but here we have keystone bros. they are a supplier for all materials that are used in the automotive industry. heres the link. hope this helps
http://www.keystonbros.com/intro.html
There's always been arguments for/against kick panel/A-pillar tweeter mounts. Fact is, there's no "quick fix always best" solution, you just have to experiment and find what you like.
Originally Posted by Hi There
The system I have installed currently is a laptop PC feeding an Alpine H701 via Toslink, which processes for my JL 500/1 and 450/4. Sub is a 10w6v2, trunk mount sealed box made to manufacturer spec. Front stage is a DLS Ultimate Nobelium 6.5" two-way set. Tweets are 1" domes that are detailed without sounding harsh, imho. Factory dash locations for these tweets are problematic in the TL, as the shape of the dash, for the passenger, blocks the driver's side tweet and results in difficult tuning for that side. Not that I mind so much, but I've also tested what the response is like with a more on-axis mount for these tweets, and it's definitely better for both seats, especially near the crossover point (3.2 kHz) as well as the region above about 7 khz (I'm going by ear here, suffice it to say it sounds a lot smoother for me, without all the windshield reflections). I've also experimented with mounting them lower, near the door-mounted mids, as well as forward near the kick panels, but I'm not a fan of the problems resulting from having a high-frequency driver blocked by my legs. I have good control over TA using the H701, and a vertical frequency graduated stage has not been a difficult thing to overcome in my car with the dash-mounted tweets. The car as it sits enjoys good stage height and vocal presence, I'm most concerned about the frequency response in the high end at this point, and both imaging and staging benefit from the A-pillar locations.
Front Stage: the 6.25''mids will go into the stock locations, the 4'' mid will get into a kick, and I am considering puting the tweet in the top front part of the door...we'll look at kicks and a-pillar locations as well...need to find the best sound. Stock locations are out...seem to require a ton of tuning to get it right...
I am having my system re-cong'd. Using three Zapco DC amps to power a 3 way front stage and two 10'' subs in the rear.
I'm jealous!
Say, have you tried out that little triangle by the midbass factory door mount location, right ahead of your door pocket storage, as a candidate for tweeter placement? Struck me as a good candidate, but didn't work quite as well for me as the a-pillars. Wide stage, but for me was too far rearward. You might give it a try, tho, and build a small pod for your tweeters there. Near-zero PLD with the mid-basses, and easy to blend into the door panel, at least.
Hmmmm...I'll have to check that location out...one suggestion made is to wire up the tweet, fire up the system and, by hand, place the tweet in different locations: dash, kicks, top of door, a-pillar on-axis and off-axis...we should get a good idea of the best sounding location that way. Ausethically, I think it will look best and most unique on the top front part of the door just below the metalic strip or on top of that strip...won't know for sure until we take the door panel off.
The installer I've got doing this is incredible, has at least one of his projects features in "performance car and audio"...should be real sweet, he starts Nov. 26th and said he'll have the car for two weeks. I'll post pics when done
Any updates? I'm doing some searching around looking for some different ideas with my system as well.
I'd love to go with a 3-way active system, but I haven't quite decided where to mount anything, if it's possible at all. I was thinking possibly a good place to mount a 3" midrange is just above the map pocket, flush mounted against the leather. Dynaudio makes a great 3" midrange with a nice looking dome grill. The tweeters could either be mounted in the dash (not likely, but at least worth a try) or high in the doors just in front of the power door lock buttons. Heck, they might even fit down near where I was thinking of mounting the midranges. Of course, I haven't even popped the door panels off to see what's behind them in terms of cutting into them. I don't think any configuration is perfectly "ideal", but I will have control of the individual crossover points, phase, and output levels for all speakers, so I might be able to tune it fairly well.
As far as kick panels go, is there a commercially available option out there I don't know about? Has anyone made their own with decent success?
Has anyone managed to fit some 8" midbasses in the stock door locations?
Tony
Tony
DiamondJoeQuimby
09-10-2015 11:40 AM
