Sound volume
Sound volume
Hello everyone ! I have an issue I noticed. When I start up car in the morning ( or when car is staying a few hours ) my music sound is very quiet. For example, on volume "30" it sounds like on "10", plus no bass. As longer I drive it makes louder, and after ~30 mins it sounds normal and bass comes back. Is it an issue or it should be like that ? 3G TL, thank you !
Search is your friend. There is a way to "usually fix" them by replacing all of the capacitors on them. Depends on your soldering skills...or just go onto eBay and pick up a used amp for $50-80 and call it good for another couple years.
I would try this: https://acurazine.com/forums/3g-tl-a...volume-922588/ first
Thank you, guys! Seems it's a common problem. With volume issue I have same quiet noise at low volume. I think I better replace it. My plans were at the spring to do audio system (new amp, speakers and subwoofer).
Rafael Rodriguez
Feb 15, 2018 09:49 AM
LivingLife90
May 11, 2017 08:17 AM
azn5ucka86
Nov 18, 2003 08:09 PM
carcaze
Sep 4, 2003 09:16 AM
