which sound processor to get?
Well i finaly convinced my friend to do a stero in his 08 accord ex modle. An well he wants to keep the factory look. an i was wondering what sound processor to use for this task.
http://www.crutchfield.com/p_236REQ5...5.html?tp=9631
http://www.crutchfield.com/p_136441D...p.html?tp=9631
We sort of want to use the mtx one to keep the cost down. But im not sure about how good it is from some reviews about the regular one.
also how would i get the remote turn on for the amp to work? do i run a power cable from the h.u to the amp?
the cleansweep from JL and the 3.sixty from rocksford fosgate are pretty good from what I hear from a few people. Your best bet would be to wire the factory turn on to the processor, and then you can take that and put it to the amps
isn't that 500 dollars for the 3sixty2..
also im guessing you dont think the mtx is such a good idea? I read on nissan forums an someother that its actualy pretty good.
Alpine imprint EQ...would be a great processor...doesn't suffer the noise that the 360.2's have a slight issure with...and does auto eq for a good baseline...mtx req doesn't do a whole lot other bass restoration...i do personally use one myself as that i'm an anti eq individual myself...using my rta on the stock system i noticed that the factory system doesn't really apply a whole lot of eq to the mix...depends on what he would like to
do with the system...what are his goals...listening tastes..ie music choice and volumes!??!
-Jason
-Jason
The stock amp has that hiss so anything after it just amplifies it .... ive listend carfully when i connected my speakers directly to the stock amp and its present just not as loud.... so i guess avoding it would be to lower ur gains a little or bypass the stock amp... the best option of course would be a nice clean aftermarket unit
-Jason
-Jason
I still have a bit of a hiss. It's VERY faint, but I still hear it. It goes away completely at volume 2 and up.
[quote=
The 3Sixty is an OEM Integration component that's designed to work with the stock head unit and amp. You would install it after the factory amp and before the aftermarket amp(s). It also does a great job of flattening out the signal so the amps have a clean, flat signal going into them.
[/quote]
I herd that it's reconmended to do it before the factory amp an to bybass it
[/quote]
Driven to Perfection
now there's a sweet deal. as long as it's not repoed or returned.
04' tl 6 spd
Has anyone tried the audiocontrol epicenter plus? it's an OEM interface processor, you tap into your rear speakers and also has aux output. if you just want to add a sub and amp
mlody
12-04-2019 02:11 PM
DerrickW
11-15-2015 05:52 PM
