Silver Trim Removal question...
Old Feb 11, 2006 | 04:38 PM
SilverJ's Avatar
So I am attempting to install the PIE 3 aux adapter.
I am removing the silver trim with a thin cloth covered flat head screwdriver.
I started on nthe passenger side near the glove compartmentv with the screwdriver digging underneath the OUTSIDE of the trim. I started to slowly work my way towards the shifter but then noticed its a little tougher to pry it up...
I DO NOT want to make the mistake many have made and bend the trim near the curve.
Should I be prying from both the inner AND outer part of the trim? Do I have to pry it all the way off up to the part near the vent?
Anyone who can weigh in on this with some specific instructions it would be much appreciated. I am probably being a bit extra cautious but this is my baby and I dont want to F it up!
Old Feb 11, 2006 | 05:41 PM
JustinZ's Avatar
umm
the aluminum trim is the HARDEST thieng to remove on the car
you will probably loose some clips
you DO haev to pry off near the nav screen.. and thats where it is the hardest - i did it once to install the music link and NEVER want to do it EVER again
what i did for the trim at the top was to get seomthing in between the nav screen and the trim to push it away from the screen and then use a screwdriver to push up from under it at the same time
Old Feb 11, 2006 | 08:22 PM
iamthebert's Avatar
I attempted the same thing today since I just received the USASpec PA11-HON2 ipod interface. I stopped after a couple attempts since I started to scratch things. I think I will take it to the dealer and have them remove the 2 trims for me. It should be a 5 minute job for them since they have the proper tool.
However, I did successfully install one in my 350Z . It was mostly unscrewing screws and very little prying.
Old Feb 11, 2006 | 08:34 PM
gt1's Avatar
gt1
` . ' . SUV haterrr
It is hard to do and you will have to use some force. This is worst part of disassembly.
Old Feb 11, 2006 | 08:52 PM
vp911's Avatar
It takes effort. I would use a plastic putty knife to help you get a little bit off. As the others have said, right near the nav screen, it takes effort.
Old Feb 11, 2006 | 09:13 PM
jjh1234's Avatar
Originally Posted by JustinZ
umm
What's wrong Justin, are you still having nightmares about aluminum trim?
Old Feb 12, 2006 | 08:05 AM
SilverJ's Avatar
I ws afraid you guys would say that!!! My DS power window stopped working so maybe I will have them take it off(the dealer) then. I am assuming I could still close myglovebox and everything else would still function if I had them take the trim off(not sure if it holds anything in)
Old Feb 12, 2006 | 11:02 AM
SilverJ's Avatar
Hmm---seems this would be a lot easier with a dash trim removal tool.
Im going out to find one. I refuse to be beaten by this !!
I am sure I will want to remove this when I sell the car in a few years so I am not going to pay someone twice to install /remove. With everyone who has done all these modifications I am surprised no one else has chimed in with some tips..
Old Feb 12, 2006 | 04:03 PM
rbf351's Avatar
Registered User
you do not need any tools to remove that trim
open the armrest, and from there start to slowly pull the trim up, it takes some force, but it will come off in a few pulls.
Old Feb 12, 2006 | 09:24 PM
iamthebert's Avatar
rbf351, you rock!! It worked!!
Old Feb 14, 2006 | 02:54 AM
rstark's Avatar
SSM 6MT
I too am waiting for my USASpec PA11-HON2 to come in. However, last night, out of curiosity, I removed the connector from the back of the radio in less than two minutes without removing any trim or anything else for that matter. This site help A LOT! http://www.fperkins.com/Audioinputan...06AcuraTL.html
Old Feb 14, 2006 | 03:40 AM
JustinZ's Avatar
Old Feb 14, 2006 | 07:58 PM
jaymd123's Avatar
Where do you plan on stashing the box? I could find any good place to put mine so I ended up sticking it under the carpet on the passenger side.
Old Feb 14, 2006 | 08:08 PM
iamthebert's Avatar
I've read that site before installation too. But I didn't go with this method because I wanted to feed the iPod cable to the passenger side. Removing the left console panel will give you more flexibility in terms of running cables and placing the brain.
Old Feb 14, 2006 | 08:40 PM
rstark's Avatar
SSM 6MT
Well, the USASpec came in today and it took around 10-15 minutes to get the new cable back onto the radio (what a pain!). I ran the main cable from the radio from the driver's side to the passener side by going under the A/C unit (pulling the carpet back on the side of the console reveals a path under the A/C). I too mounted the brain and excess cable under the A/C on the passenger side right above what appeard to be a electrical terminal box (remove the carpet screw on the passenger side console so you can pull the carpet back).
The iPod cable just comes out from the passenger side of the console (towards the back). I have the ProClip mount on order (backorder) so for now, the cable just rests next to my shifter. The sound is pretty good, but I'll have to play with the EQ on the iPod since loudness (what I had it set to) is too bassy and flat is, well, too flat.
Old Mar 18, 2006 | 12:45 PM
luniz97's Avatar
anyone in san francisco want to make 50 bucks to come put it in for me?
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
spoiler900
Oct 10, 2015 06:48 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Desert Ridge
Sep 27, 2015 02:37 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
