Screen brightness with Doms PNP and camera TOO BRIGHT
ElectroMechanicalEngineer
Got my Boyo VTL 375 and Doms PNP installed, all is good except the brightness is wayyy off. Using the buttons on Doms unit i tried changing the brightness....and nothing happens. I push the buttons repeatedly then ill hold the button...nothing happens...
Pics using iPhone...inside you can see its really really bright where the asphalt is, and im parked in the shade...
pics from behind the car...
did you try turning the brightness up? If not, try it and see if dom's is maxed to it's dimmest setting. If it is, plug your camera into a monitor and check and see if it's the camera.
Talked to tech support at TvandNavtogo.com and the guy said i have to press the brightness buttons many many times, the floor and ceiling is around 60 steps and the changes are small with every press.
Gonna try this later today
Did you try the factory reset by pressing the up and down brightness buttons at once? Or pressing the down button 60 times? HAHAHA
Yeah i did both, i pressed the button maybe 100 times and i saw no change in the brightness whatsoever
Sooooo....
Hooked the camera to another monitor...and the picture was perfect...all i did was take the RCA connection to another monitor and didnt move or adjust the camera.
Hooked up a DVD player to Doms PNP to video 1 and then video 2...looked at the screen both times...kinda bright but i could adjust the brightness on Doms unit...but cant adjust the brightness at all when the reverse camera is on...
So my guess is something wrong with Doms unit itself...gonna call TVandNav to go on monday/tueday and see what they think.
navtool.com
31
11-16-2015 08:30 PM
