Routing wire for a hardwire?
Old Mar 24, 2010 | 10:03 PM
SpiderX1016's Avatar
I'm going to hardwire my Radar Detector on friday.
I'm going to put it low on my windshield but I was wondering how did you guys route the power wire back to the fuse box.
Old Mar 25, 2010 | 01:46 PM
Andruha88's Avatar
SpeedDemon
Look here
but i would mount it as high as possiable
Old Mar 25, 2010 | 05:58 PM
Originally Posted by Andruha88
Look here
Thanks, I'll check it out when I get home.
I don't like it high cause it bothers me.
Old Mar 25, 2010 | 07:49 PM
dwb993's Avatar
That's not a bad way to wire it. You could also tap in the HFL to avoid running the wire all the way across and down. There is a thread here somewhere detailing this.
If you do use the fusebox, make sure to get an Add-A-Fuse instead of just jamming the wire into the fuseblock like that guy did. That way you are absolutely sure you are running a fused circuit.
Old Mar 26, 2010 | 10:24 PM
I hardwired my Escort today. I wrapped the power wire with one of the fuses for Power rear windows.
hmm, I used the same ground as that guide did too. It was a lot easier with the plastic things off lol. I tried hard to do it with it on but I had to take it off when I lost the bolt.
I then routed the wire up and went along the a pillar and along the windshield.
Acura604
20
Aug 5, 2017 12:55 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
