Rockford fosgate 3sixty install question?
I've been reading many posts concerning audio installs. I am considering the purchase of RF 3sixty for my system. I was wondering if the input to the 3sixty should come directly from the head unit and bypass the factory amp or after the factory amp? Also for those who have the 3 sixty, did you use speaker wire or RCA inputs. Thanks.
Klope
Klope
Welcome aboard Klope!
Have you tried performing a search? There are many threads on the 3sixty. Try a keyword search with *sixty.
Here is a good one for you: my custom audio system upgrade w/ 3sixty!
Team Anthracite Member
Summary of your search results:
Go from after the stock amp, not before. The 3sixty takes a high-level input and (very nicely) converts it to a line-level output for amps.
Skirmich
09-15-2015 06:41 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
2006, 3sixty, acura, amp, factory, fosgate, install, installation, installations, installing, mdx, questions, rockford, tl
