Replacing a speaker in an '04 TL
Old Feb 22, 2011 | 01:45 PM
loosecrew's Avatar
3rd Gear
I just recently purchased an '04 TL and one of the stereo speakers (passenger side door) is blown. The part is pretty cheap but wondering if anyone has installation instructions or suggestions? Am I better off letting the dealer install the new speaker? Thanks in advance...
Brian
Old Feb 22, 2011 | 09:22 PM
Evolution22's Avatar
Google or use the search here i did the same make sure you get the harness or you'll have to do the setup i did with one bolt holding the speaker in! Good luck its a real bitch lol
Old Feb 23, 2011 | 09:05 AM
jda123's Avatar
Dogmatic Dinosaur
You will need to take the panel off. There are 4 screws - 2 behind a cover near the handle, 1 inside of a bumper pad on the rear of the door and 1 on the lower part of the armrest (you can see the hole). Then, you have to pull the panel off - there are about half of a dozen plastic clips. From there, you just unscrew the speaker and replace.
You can search on here for door panel removal. It might even be in the 3G garage. There are some nice scans of the service manual that will walk you right through it.
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
Pegon95
Sep 15, 2015 01:54 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
