Replacement Cingular V600 has same problem
Old Sep 15, 2004 | 11:42 PM
PAR5zN2's Avatar
Got the replacement V600 from Cingular today. Still has to have the clamshell open to recieve a call via the HFL. Called the HFL folks and they said they've been getting the same type calls all week from folks who got the V600 replacement from Cingular.
Anybody have a solution other than getting a different model phone?
Old Sep 16, 2004 | 12:02 AM
bluedragon's Avatar
That's weird....I just bought a new one on 9/10/04 & I can recv calls with it open or close...having the bluetooth on just kills my cell battery really fast, I need to go get a car charger.
You could wait on the new 551 or Razor phone from Motorola if you prefer Moto's like me.
Old Sep 16, 2004 | 08:22 AM
TXTL's Avatar
Replacement Works
I got a Cingular V600 replacement last week and it works great with the HFL. So far, all incoming calls with the clam closed have transfered to the HFL. My new software has a _A1 at the end which I didn't have before. I did not change any setting on the new phone just paired. The one thing I do a little different is that I turn on and off the bluetooth manually (save battery life). I've made a shortcut on the phone so it's easy to turn on and off. Once the HFL picks up the bluetooth connection, I close clam and sit back...
Old Sep 16, 2004 | 09:38 AM
PAR5zN2's Avatar
Could you check the following settings that this board recommended and see what your settings are set to:
Auto Answer - Off
Auto HF - On
Power-Off Delay - Continuous
Charger Time - Off
Old Sep 16, 2004 | 10:49 AM
TXTL's Avatar
Auto Answer - Off
Auto HF - On
Charger Time - Off
The only difference are the last two setting. They wouldn't affect the HFL
Power Off Delay - 60 Minutes
Charge Time - 1 hour
The V600 A1 S/W makes no sense to me. I have no idea why some work and some don't...
Old Sep 16, 2004 | 07:50 PM
mobilezen's Avatar
If you have a data cable, you can upgrade your own firmware...although Cingular would frown upon it, there's not much more you could do except keep swapping out the phone with them.
Old Sep 18, 2004 | 05:58 AM
nortynorty's Avatar
Par, my v600 with Cingular operates with the phone closed. I paired mine yesterday morning and was in and out of the car several times with the phone in my pocket and it seemed to work fine...although I did not have it set to auto answer...I then learned that pushing the talk button on the steering wheel is not the same as on the phone. The battery drained fairly quickly. Just this morning, I turned off the event lights to see if that saves any battery life.
Old Sep 18, 2004 | 01:19 PM
PAR5zN2's Avatar
What settings do you have? Are they:
Auto Answer - Off
Auto HF - On
Charger Time - Off
Old Sep 19, 2004 | 07:06 AM
nortynorty's Avatar
Auto Answer: 5 Seconds (Haven't tried this yet...had it off and then pressed the phone icon on the wheel thinking it was like talk on the phone and didn't get the call)
Auto Handsfree: On
Power-off Delay: 60 Minutes
Charger Time: 1 hour
Software Ver:TRIPLETS_G_08.09.0FR_A1
Old Sep 20, 2004 | 05:22 AM
pinito's Avatar
Care to share the shortcut? I woul like to establish one.
Old Sep 21, 2004 | 02:10 PM
JetJock's Avatar
anyone know when the razor is going to be released? That is one cool looking phone.
Old Sep 22, 2004 | 11:15 PM
csunracer's Avatar
I like you, do u like me?
You need the firmware update. I just got my TL on saturday, paired my phone with the car and was experiencing a similar problem. I could not answer any incoming calls, but could make outgoing ones. I updated my firmware today using a data cable and the phone now works great in my TL.
Old Oct 25, 2004 | 04:28 PM
ChrisMc73's Avatar
04' Acura TL Anthracite
What about the options in the "In-Call Setup"...then go to Answer Options...then Open To Answer set to "off" or "on"???
Old Oct 26, 2004 | 11:34 AM
nortynorty's Avatar
My Open To Answer is set to On, but I can still get calls in the car with the flip closed.
Old Oct 27, 2004 | 04:31 AM
JetJock's Avatar
My V-600 works flawlessly with the TL. It's ATT, but has worked fine since day one.
Old Oct 30, 2004 | 11:21 AM
I have the v600 through Cingular and I can make out going calls, but incoming calls will not answer through HFL. It just hangs up on the person, or I have to pick up the phone and answer it that way.
Old Oct 31, 2004 | 05:30 AM
nortynorty's Avatar
JMan, Are you using TRIPLETS_G_0B.09.4AR as your firmware? I'm also a Cingular customer and had the same problem with the s/w version which came with my phone, but it is working better once I flashed to 9.4AR.
Old Dec 8, 2004 | 01:20 PM
Xpditor's Avatar
"Is this the party to whom I am speaking?"
V600, 2004 TL, AT&T.
Answering incoming calls via steering wheel button:
Press the phone icon and then wait until you see "In Use" on the MID. You can also hear some hum on the speaker indicating the calling party is there. Then, say "Hello".
There is a delay for some reason of about 3 secs between pressing the button and answering.
If you get anxious and press the button again, you can drop the call.
Just wait for the "In Use" and you'll have no problem.
cycdaniel
Dec 17, 2019 10:58 AM
spidermankb
Mar 5, 2019 11:34 AM
HOWELLiNC
Sep 5, 2015 03:09 AM
NSolace
Sep 3, 2015 08:02 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
