Remote starter with factory keyless remote??
Old Apr 13, 2009 | 04:01 PM
some1's Avatar
You know him right?
Question Remote starter with factory keyless remote??
Does anyone know if this is possible or exists? I'm thinking about eventually geting a remote starter but dont want 2 remotes. I know other car manufacturers have the option where they replace the original keyless remote with a new one that supports the added remote started.
Any thoughts?
Old Apr 13, 2009 | 04:06 PM
djwoody's Avatar
Good question.
I'd also like to know if there are any issues installing a remote starter with the 6-speed manual transmission.
Old Apr 13, 2009 | 04:41 PM
ABP_04TL's Avatar
6-SPEED LOVER
Originally Posted by djwoody
Good question.
yes is possile bout installin it on a 6spd ask Acpimpin!
he has it on and ive seen it in action
Old Apr 13, 2009 | 05:49 PM
georgegiorgio's Avatar
G Force
Is the remote starter from factory?
Old Apr 13, 2009 | 07:08 PM
hata_61's Avatar
Acura in canada has an OEM optional 2way remote starter. But the range is no where near the aftermarket units(Compustar,Autostart).If you want to Use an aftermarket unit and retain your OEM alarm functions then look at getting an OEM integration unit like the Idatalink.I personally have it and installed it and it works like a dream. It does immobilizer bypass,door locks,trunk,OEM alarm,Tach signal,Hood pin(no need to have wire pass thru firewall). take a look for youself http://www.idatalink.com
Old Apr 13, 2009 | 07:16 PM
hata_61's Avatar
The new 09 TL OEM 2way starter installed price is $875 CND, i would say the price for 3G would be very close around there. maybe its a bit cheaper since its the outgoing model. Give a local acura dealer a call to see if they have it or not. If they dont then call up your closest canadian dealer and see how much they want for the kit.
Old Apr 13, 2009 | 10:22 PM
fade2blk's Avatar
yes it is possible, and I did one myself on my 06 tl. like above post stated you will need to get a bypass, then you can get any remote start add-on.
http://www.google.com/products?hl=en...-8&sa=N&tab=wf
the way the add on's works on factory remotes is quite simply. the triger connects to a parking light or door locks.
then you program the remote start on how many clicks it will take to activate it. the way I had it on mine is on 3rd press it would activate remote start.
hope this helps a little.
good luck
Old Apr 13, 2009 | 11:26 PM
G Force
good luck
I have a question, once you use the remote starter, the car's engine would start, is the car safe?
Like anybody would just hop up and drive away?
Or does it still need your key in the ignition to unlock and unblock the steering wheel and engine immobilizer?
Old Apr 13, 2009 | 11:38 PM
vipernj's Avatar
Yes it is very possible.
Any Directed Electronics or Compustart system will work fine. The installer just needs to diode isolate the lock wire and wire it to the activation input (white/blue) on any DEI model. Depending on how they set it up it can remote start the car by hitting the lock button a few times.
You will have barely any range on it though, I say scrap the factory remote and use the aftermarket one.
Installing on a 6 spd is just like installing on an auto. They can diode isolate the clutch wire with the status output wire (blue) so that it will start without bypassing the clutch. Just don't leave it in gear because unlike subarus, i dont think acuras have a factory neutral safety switch
Old Apr 13, 2009 | 11:39 PM
vipernj's Avatar
The brake wire is wired up. If anyone taps the brake pedal without the key in the car will die.
Plus the car will still be locked
Old Apr 14, 2009 | 07:19 AM
Trew's Avatar
When you install a remote start on the 3G, you first have to unlock the doors and then start the car, otherwise the factory alarm will go off. You can then relock the doors after the car starts.
The factory alarm arms when the doors are locked. Starting the car with a remote starter triggers the alarm. I have yet to see a solution to bypassing the factory alarm with a remote start on the 3G.
Old Apr 14, 2009 | 07:53 AM
fade2blk's Avatar
trew is right. if you are using factory alarm. you have to disable the factory alarm to activate the remote circuit. and yes once started you can lockit via keyvob.
if you want to retain the car locked on its own with remote start. with out extra clicks with remote then one will need to get aftermarket alarm with remote start and tie that into the factory one.
Old Apr 14, 2009 | 08:49 AM
some1's Avatar
You know him right?
Thanks for great replies. Thats a lot of info and now it seems like I have some decisions to make. I really want to keep the car stock (for now since I just bought it) so those options sound alright..except for the open the doors, start the car, then lock the doors (I can imagine I will forget to relock the doors at least once)
I will wait to do anything for now. Maybe go through a winter and see what its actually like. Although I can only imagine it will be nice and cool..as usual.
Old Apr 14, 2009 | 09:16 AM
fade2blk's Avatar
some1, depends on the remote start module that you get. some of them have a option to relock the doors after the remote start activated.
good luck.
Old Apr 14, 2009 | 06:13 PM
hata_61's Avatar
my car locks by itself when i command it to start, and it works exactly like the OEM remote, but just 1000x the range.
Old Apr 14, 2009 | 09:46 PM
vipernj's Avatar
If that is the case, then someone installed your remote starter wrong...... Factory disarm wires can be used to disarm the factory alarm via the control board inside the drivers door. You shouldn't have to unlock anything... at all
Old Apr 15, 2009 | 01:58 PM
Fulani has a TL's Avatar
PITA to run wires into the door panel, but I am going to have to do that
Old Apr 15, 2009 | 05:40 PM
hata_61's Avatar
Unless you have a 2G TL i dont think you need to go into the door. everything is done by the data wires.
Old Apr 15, 2009 | 11:12 PM
fade2blk's Avatar
not at all, and no you do not even have to go inside that panel. get the proper bypass module and it will tie into the factory for you. look for CAN Bus bypass
http://canbuskit.com/cansl.php
http://www.bypasskit.com/
and there are so many others....
do not limit your self of thinking that you will have to go inside the door panel.
good luck
Old Apr 16, 2009 | 07:33 PM
GTA_TLS's Avatar
RonJon/Kaption/Clifford
Good question.
No issues, I have it on my 07 TLS with window modules too and was done here in TO.
Clifford Matrix 3.3 is what I have.
Old Apr 16, 2009 | 10:44 PM
good luck
Using Can-SL and Honda-SL2 units for bypassing.
Jul 16, 2017 07:33 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
agupta3224
Sep 22, 2015 08:08 PM
