remote start
Old Feb 1, 2007 | 04:43 PM
tonyph33r's Avatar
remote start
hi my friend install the remote start and it work fine with a differe remoter is there a way i can make it work on the Acura Remoter?
Old Feb 2, 2007 | 05:41 PM
rajtl's Avatar
there are remote starters out ther that can be used with the stock remote.the only promblem with that is the range on the stock remote isnt very long and when the car is running u wont be able to unlock the doors with the remote you will have to turn the remote starter off and then unlock the car or use the key.i hope that helped.
Old Feb 2, 2007 | 10:56 PM
tonyph33r's Avatar
thanx
Old Feb 3, 2007 | 08:28 AM
rbf351's Avatar
Registered User
not true, if you wire it correctly you can open and close the doors when the remote start is running. i've installed remote starters on my 05 TL, and my 05 Civic, and both can be unlocked via the remote when you have the car started via the remtoe start
Old Feb 4, 2007 | 05:18 PM
rajtl's Avatar
i was talkin about if you use your factory remoet of cause it will lock and un lock when using a after market remote
Old Feb 4, 2007 | 05:29 PM
SteveP66's Avatar
Kaa - Ching !!!
From: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
I'm glad my factory fob wasn't hooked up to my starter - the factory remote fob has no range at all. The remote start I have let's me start my car from my desk at work. 3 floors up and the car parked about 6 double rows back in the parking lot.
Old Feb 4, 2007 | 09:09 PM
rbf351's Avatar
Registered User
and so am i, if you use an add-on remote start with the factory keyless entry, you can still use the keyfob to lock/unlock the car after it is remote started. if you can not use the stock keyfob after the car is remote started then you hooked it up wrong
oyayjoe
Jan 1, 2019 10:17 PM
oyayjoe
Sep 12, 2015 04:40 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
datadr
Sep 2, 2015 06:46 PM
