Remote amp turn on 12V
Old 08-04-2006, 11:05 AM
morgan040's Avatar
Does any one have any PICS for were they got their 12V remote turn on at.
I would love a pic from the xm remote turn on in the trunk or ........someplace easy to get to.
Old 08-04-2006, 12:02 PM
datmrman's Avatar
No pictures in these threads, but a there are few good descriptions:
Remote 12V amp trigger
Amp Remote Wire Help
Old 08-04-2006, 01:20 PM
morgan040's Avatar
I've tapped into fuse boxes before but they were BIG fuses. These new cars have tiny fuses and I have no idea how to tap into a fuse like this a picture or a discription of how to tap into the fuse box would be great.
Old 08-04-2006, 02:00 PM
Crook's Avatar
I remember seeing an image in this 12V accessory wire thread. This might help although it is not at the trunk like you asked.
The fuse tap is from Radioshack but they are designed for the larger fuses. Carefully use a grinder to grind down one end until it will fit together with the mini fuse. It's a four pack so you'll have 4 tries to get it right. You're going to need to use pliers while grinding because it will get pretty hot.
It's pretty simple to run a remote wire from the fuse box to the trunk.
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
09-17-2015 09:01 PM
Pegon95
09-15-2015 01:54 PM
Quick Reply: Remote amp turn on 12V
