? regarding Navi
? regarding Navi
On my '08 base... I've always wondered if this is just a flaw in the software, or if something is wrong with my Navi unit.
When I have it set to "Auto" (adjusting for day time or night time), it never switches to night. It doesn't do it automatically... And it doesn't matter if I have the headlamp switch to "auto" or if I turned the headlamp switch to on/off.
It's the only thing that seems to be wrong with the unit so I never made a fuss to bring it to the dealers to have them check it out. I just assume it's a flaw in the software. I've just adjusted manually myself going into setup and dimming it at night and changing it back to day during the day.
But am I wrong? Is everyone else's Navi properly adjusting itself between day/night time settings when set on Auto?
Yep. Set it to "auto" via the setup button on the console control. I never use the "auto" for the headlamp control (other than the few times I was testing out the Navi to see if both were linked).
when ur headlights turn on the navi screen should automatically dim too ... if u have set it on auto in the nav ... otherwise i would think something is wrong, make sure that you dont have the dash lights set to max cuz then it wont dim with the headlights
Registered but harmless
Received 1,107 Likes
Then turn the headlights on-- the Navigation screen should then automatically go into night mode whenever the headlights activate, either in "Auto" or "On" position.
Hm... interesting. That is something that I hadn't tried yet. I may have my dash lights set at max. Thanks for the heads up.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
us285126
10-02-2015 02:03 PM
