Radio problem help
Radio problem help
Like 3 days ago i was changing my cds and then stop working.. u can hear the cd like changing inside but it dosent let me put it in cd so i just put the aux and it plays good.. but today my radio start acting crazy the radio sound like when you connect u phone for the aux with the volume high u know what i mean and the sound drop complete after 5 min.... dosent let me put the volume back up unless i shut the radio and turn it up agian some times change the radios station alone too .... when u put the aux or radio u can still hear the cds triying to change and radio moving inside triying to do it but the other day the aux and radio was working just find and i was hearing that same thing all this time u think the problem is relate now or can be a loose fuse thanks
Registered but harmless
Received 1,106 Likes
Sorry, but nobody understands what you wrote.
"42" is an inside joke originating in the Ramblings forum.![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Some punctuation and better use of grammar in describing the symptoms would help diagnosing your TL's issue. Right now, I can't tell what you mean other than you have an issue with the CD player and some sort of issue using the auxiliary input.
If your TL has an iSimple or some phone adapter, disconnection and reconnection tends to solve most of the problems.
Welcome to AZ.
Welcome to AZ.
Welcome to AZ.
Welcome to AZ.
Aaphree
68
01-07-2024 06:56 PM
STL acura
05-07-2017 03:24 PM
FLowRiter
03-19-2016 08:10 PM
KayBee
02-14-2016 12:39 PM
