Quick preview of my system project
Old Oct 7, 2009 | 07:35 PM
DiamondJoeQuimby's Avatar
Codename Duchess
Well, I plan to run the preamp from the stock deck into a Zapco DSP6-SL but I didn't want to cut anything...so...
Made up a harness that plugs into the stock amp input harness in the kick and soldered on F/R/S/C RCA cables.
All HFL and NAV audio is switched through the h/u not the amp. Tested by plugging in a small amplified speaker:
More details and pics as I progress...
Old Oct 7, 2009 | 08:27 PM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
looks good! i like.
Old Oct 7, 2009 | 10:23 PM
BlueAc's Avatar
Acura drove me away too..
Hmmmm... Wanna make me one! Looks good...
Old Oct 7, 2009 | 11:51 PM
RBeachTL's Avatar
Looks great. I'm trying to do the same thing but I can't find the connector. Can you please provide the information on how you got that connector.
Thanks,
John
Old Oct 8, 2009 | 07:57 AM
Codename Duchess
it is the same connector used from the PGHHD2 harness for the PXAMG or the PA15-ACUxl. I got the PGHHD2 since you can buy it separate from the PXAMG for quite a bit less.
Old Oct 8, 2009 | 01:56 PM
Gary Mac's Avatar
Back up, this is exactly what I need - I dont know anything about the harness you speak of. What is it and where do I get it?
Old Oct 8, 2009 | 04:19 PM
Codename Duchess
http://www.peripheralelectronics.com/?ProductId=467
it is the female 20 pin in the pic. It all comes as 1 so I also have a 20 pin male and a PXAMG ipod cable if anyone needs one
Old Oct 8, 2009 | 08:40 PM
Gary Mac's Avatar
Thanks for the link, how do you buy one?
Old Oct 8, 2009 | 08:43 PM
Gary Mac's Avatar
Nevermind,
Old Oct 12, 2009 | 03:03 PM
RBeachTL's Avatar
I've been looking for this for six months. How did you know that the PGHDD2 harness connector would work.
I agree with you that splicing into the factory wire harness is a bad idea. I ordered a connector harness from one of the online install sites that was the wrong size. I already have one of the PGHDD2 harness in my trunk; I only wish I would have know that this was the correct connector sooner.
Thanks for the find!
John
Old Oct 12, 2009 | 04:34 PM
mmade22's Avatar
200,000 mile club
Nice, great job!
Old Oct 12, 2009 | 07:04 PM
Eiswritsat's Avatar
TL owner
looks hot, if i every get my car back from the dealership and they fix my radio im gonna get around to installing my new zapco DC360.4, i got it for a sweet deal. I had to finally let go and sell me jl 4 channel. Can wait to use the USB laptop tuning. Im sure your going to have fun with that set up. Great job on the connector, very clean
Old Oct 12, 2009 | 09:01 PM
Codename Duchess
John
I work at a shop and had been waiting for the PGHHD2/PXAMG or the USA Spec PA-15ACUxl ipod interface option ever since I bought the car back in April.
I installed the PA15 when it came out and didn't think anything of it. (knowing what my long term plans were for the system).
Had to take the car in for service on the NAV-DVD drive and pulled the PA15 out just b/c I didn't want to deal w/ the dealer saying that caused the problem.
Well I had the PA15 sitting in the pass. seat to go back in when I took the amp harness out to figure out the pin out and realized the connector was very familiar. Reached up to the seat, grabbed the harness and found that is plugs into the amp as well as the XM box. I then realized the PGHHD2 plugged into the XM box the same way as the PA15 so the harness must be the same, plus the PGHHD2 is available by itself w/o having to have to get the whole ipod interface.
Old Oct 13, 2009 | 12:30 AM
RBeachTL's Avatar
That's a great story. I'm going to be splicing symbilink cables onto the PGHHD2 cable and running these to some DC amps.
Thanks for writting this up and posting.
Old Oct 13, 2009 | 09:50 PM
Gary Mac's Avatar
WHy dont you splice the RCA's like he did and run them into a zapco slb-4 for a balanced input and take the symblink from there into your DC amp?
Let me know how that turns out.
Old Oct 13, 2009 | 11:39 PM
RBeachTL's Avatar
Why don't you splice the RCA's like he did and run them into a zapco slb-4 for a balanced input and take the symblink from there into your DC amp?
Good question. The answer is I think; because the slb-tp4 with the rca connectors expects that the rca inputs are unbalanced. Our TLs have balanced outputs and they have almost the proper characteristics to feed the DC amps. The HU outputs are pretty low voltage and need some amplification for best results into the DCs. And I'm going to use the slb-u as the balanced pre-amp prior to sending the signal to the DCs. So to feed the slb-u I need a symbilink cable and my choices are to splice the symbilink cable to the harness directly or to splice rcas on to the harness and then use the slrcm cables with rca inputs and symbilink outputs. I am going to splice and avoid one more set of connectors.
I think what I've said is correct. If I've got something wrong please let me know.
Thanks,
John
Old Oct 14, 2009 | 04:53 PM
bzyrice's Avatar
Wow. clean.. love stuff like this! I lvoe using stock harnesses..
Old Oct 16, 2009 | 01:43 PM
xxx_busa's Avatar
Shit ...... Good Job,
Now if I can get off my ass,
I bought way to much stuff for my car,
Now I need Symbilink wire and other goodies,
Its gonna look like a Zapco retail outlet when I'm done
Amps
US Amps TU 600
Zapco Ref 200.2
Zapco Ref 350.2
Zapco DC Ref 200.2
Zapco DC Ref 360.4
Zapco DC Ref 500.1
Zapco DSP 6
thinking about Hybrid Lagetia 841 w/ pro tweets
Old Oct 17, 2009 | 03:38 PM
uncald4's Avatar
Former Sponsor
That is frickin awesome that you had the brain to try that out. Mad props!
Looks like I should start stocking up on more PGHHD2 harnesses.
Would anyone be interested in a group buy for this completed harness? I could probably do a complete re-pin of that female plug.
Old Oct 17, 2009 | 05:01 PM
Codename Duchess
you don't even need to re-pin it. All 20 pins are in the PGHHD2 female harness. There is also an amp turn on in there (that I didn't realize until after I made it).
Old Oct 18, 2009 | 01:39 PM
uncald4's Avatar
Former Sponsor
I would still prefer to re-pin the harness. A clean audio signal depends on as little resistance as possible in it's path. By re-pinning the harness I could eliminate any solder points or butted connections between the harness and RCA connection. The result would be an unrestricted path with no weak point.
Depending on the outcome of a solid harness I would definitely offer compensation for your hard work and ingenious idea.
Old Oct 18, 2009 | 05:30 PM
csmeance's Avatar
Unless you are a vendor on acurazine, there is no having Group Buys or feeler threads.
Old Oct 19, 2009 | 08:20 PM
I hate cars's Avatar
Absolutely!
Old Oct 19, 2009 | 09:34 PM
rbgilparra's Avatar
Hey Travis, i would be interest in one of these; if you decide to make them.
Old Oct 25, 2009 | 08:29 PM
tragichero's Avatar
My Other Ride is a Huey
YES!
Old Oct 31, 2009 | 08:52 PM
RBeachTL's Avatar
Hey Diamond Joe,
I got a cable from Uncald4 and I'm starting to wire up come symbilink connectors. I ran into a problem; pin number 5 on the female connector is missing. Does your connector have all of the pins on the top row? I think this pin is for the center channel + signal. Because the TL audio outputs are balanced when you used the speaker as a tester I'm guessing that the (-) signal was sufficient to drive the speaker. Did you notice if the output volume for the center channel was lower than the other speakers?
If Travis reads this; is there a way to move one of the unused pins to position 6?
Thanks,
Old Nov 1, 2009 | 05:26 AM
RBeachTL's Avatar
Don't you feel stupid when you answer your own questions.
Yes you can move one of the unused pins to position 5; it's really easy. The connector shell has a catch that you push away from the pin to release the pin. The wire slides out very easily.
I'm now back in business and wiring up my symbilink connectors.
Old Nov 3, 2009 | 08:36 PM
Codename Duchess
hmm. weird you were missing a pin. Mine had all 20 pins in it. Glad you got it figured out. I am slowly making headway on some other tidbits i need to get done before I really dig in. Hopefully sound deaden and run wires soon.
Old Nov 8, 2009 | 02:14 PM
RBeachTL's Avatar
Just finished making my harness adapter:
Thanks to DiamondJoe and Travis
I wasn't too bad but I highly recommend getting the mini DIN6 connectors with crimp adapters. I got mine from DigiKey.
As I posted earlier it was pretty easy to rearrange the pin configuration on the 20pin connector once I found the release catch. I have all but one of the connections that are in the stock connector; the amp mute connection. Does anyone know what that actually does? I thought I've read that all processing for the HFL and nav voice are accomplished in the HU so I can't figure out what this signal actually does when sent to the amp?
Now all I have to do is finish my amp rack and it's install time.
Old Nov 18, 2009 | 08:24 AM
JerZDevil's Avatar
If I use the OP's harness, can i just use the SLDIN-TF that came with the DC Ref amps?
(PGHHD2 - SLDIN-TF - DIN/DIN 18' cable - DC Reference)
I was told to use a BTLF Hi/Lo converter with an SLBU or 2 to the amps.
I hope this is another option that I can look into.
Old Feb 25, 2010 | 09:16 AM
HarlemzFinest135's Avatar
Does anyone know where I can get a plug which connects to the output connector on the stock amp. I want to catch the signal after the amp and use a Rockford 3sixty.1 to switch the signal to RCA
Old May 28, 2010 | 05:32 PM
wrxyboy's Avatar
1st TL-S on air in
^^^ i was wondering the same thing to if the other end of the PGHHD2 harness could plug into the output side of the stock amp.
Old May 28, 2010 | 09:01 PM
DoubleM68's Avatar
3rd Gear
Help Noobie
I would love to have all the details on the making of this rca bypass harness if possible This is my first post
Old May 28, 2010 | 09:12 PM
Nick337's Avatar
its pretty easy, get you a pinout and remember it takes two wires to make one rca plug
Old Jun 11, 2013 | 05:43 AM
2tempting's Avatar
where can i buy this adapter??? really want to do this this is exactly what i need but cannot seem to find it
Old Jun 11, 2013 | 07:50 AM
abirvalg's Avatar
have you heard of google before?
well, here's for your searching effort inside the forum
not easy to dig up a 4 year old thread!
http://www.amazon.com/gp/offer-listi...&condition=all
Old Aug 1, 2013 | 04:16 PM
alan_rich's Avatar
05 TL A-Spec
Sorry for my ignorance but what Exactly does this piece allow you to do or what purpose does it serve? Not being a smart ass just trying to gather as much info as I can to find out the best way to install a system in my 05 TL while keeping the stock deck and speakers.
Old Aug 1, 2013 | 04:47 PM
abirvalg's Avatar
it matches the preamp adapter of the stock amp
so you can get preamp signal without cutting stock wires
Old Aug 1, 2013 | 06:17 PM
alan_rich's Avatar
05 TL A-Spec
Abirvalg your an animal! Why do you need preamp signal? What does it hook to and then power?
Old Aug 1, 2013 | 06:36 PM
abirvalg's Avatar
preamp is cleaner and closer to source
you don't amp it (in the stock amp) and then remove the amplification with the LOC only amplify it again with an aftermarket amp
it allows you to bypass stock amp and thus have less equipment in the chain
all amps take pre-amp, but not all work well with balanced input
search for someone hooking up an amp directly to the HU, to find out which ones work for sure
