Question about the Audio code
Old Oct 15, 2007 | 10:09 AM
millrtyme22's Avatar
8th Gear
I just purchased an '05 TL Saturday. The dealership only entered the Navi code and not the audio. They said to disconnect the battery to put in the audio code.
Is there an easier way to do this without disconnecting the battery?
Old Oct 15, 2007 | 01:06 PM
01tl4tl's Avatar
Normally you enter both codes after the battery was disconnected for some reason
Some models- the radio security locks right away but the nav holds power for 15 minutes or so
If they failed to do that for you- simply remove the NEG cable from battery, and reinstall
That will make the radio code screen come up for entry
You bought it used at acura dealer- correct?
Go back and make them do it - only takes a minute and your car should have had it working before delievery
Mention you belong to acurazine.com the LARGEST internet forum membership of acura owners- wouldnt they like you to tell us what a great job they did, or should you post- here is the name of a place too stupid to put the code in after battery died from sitting on the sales lot for so long
From a 2 bit operation that doesnt know acuras I would expect this- but an acura dealer!!!!
Old Oct 15, 2007 | 01:08 PM
01tl4tl's Avatar
Make sure you have those codes written down- then join acura.com and store them there for free https://www.ahm-ownerlink.com/login.asp?brand=acura
Write them in permanent marker under a fuse box cover in the engine compartment- or on the side of the glovebox door- or under the cup holder
Somewhere the next owner can find them!!!
mada51589
Jan 9, 2025 04:40 PM
Yikes
May 3, 2021 04:29 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
