problem hardwiring radar
boost 3G
i just got my valentine v1 in the mail and tried to hardwire it but every fuse i tap into with the connect a fuse thing the radar stays on all the time no matter what fuse i use. even the radio fuse. anyone know why this is happening? thanks in advance guys!
Your fuses always are supplying voltage to the units they power, it's just that the units are not always drawing current.
You need to remove the lower dash (very straightforward) and find the BLACK/YELLOW ignition wire or the BLACK/RED or WHITE/RED accessories wires (there are two, tap either wire) ..
these will therefore only supply power in the event that the ignition or accessory circuits are powered. And make sure you use a fuse in-line with your power supply for the V1 ...
Fuse #32 is the right one...
Being an Acha Bacha in
I knwo the search has been not workign lately.. but all you have to do is ground it to any one of the bolts up there and then figure out which wire is hot up there.. and if memory serves correct I wanna say its the green wire w/ stripe but I'm not 100% so if you have a meter.. just test it and that should be it..you're good to go.
Radar detector will shutoff after 30 seconds of takign the keys out of the ignition or once you open the door.. because remember power is still running in the car to roll any windows up and stuff for 30 seconds or door opening, whichever comes first.
This will take you no more than 15 mts. do from start to finish no joke. I did it in the dealers parkign lot after I took delivery with the salesman watching and learning... Haha. And you can tuck all wires right up there as well so no need to run anything down any pillars and such. Simple and easy.
i have one quick question.
i have a cobra detector, and am planning to have a friend hard wire it tomorrow. what i need to know is, what else do i need besides the cobra and the cigarette lighter? and does anyone have a manual or a step by step on how to do this?
help a newb who knows nothing out...
Step by Step DIY is on the forums.. however the search is not working..so sorry can't help. I'd say do a search tommorow or Tuesday and pray that its up and working. Everythign I said in that post is available with pics for you guys. No point in me doing it all over. Pointless.
results:
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/v1-install-552627/
Take the easy way out..
Get an Invisicord (Google search) then follow these instructions...
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/anyone-know-these-power-wire-pics-556435/
Mine has been working fine for months, no fuses.
I remember there was someone who had a radar detector in the front of the TL behind the grill? That looked really cool because no one could see it from outside. I can't find the link though. Anybody know if it's worth it? Easy to install?
SidhuSaaB
05-30-2020 12:40 AM
