Power wire subwoofer
Old Jun 23, 2011 | 05:27 PM
prowheelie92's Avatar
hey guys so i been pretty much doing a lot of research since im new to all of this audio sutff. So im planning on running the power wire through the rubber gourmet by the left of the brake pedal. i looked at it and im not exactly sure how to fit it through. people have said to stick a screw driver but im afraid to damage any wires. also what guage wire will i need for a 700 watt amp? Also does anyone know how to get the power wire from the rear seat to the trunk. help is much appreciated.
thank you. btw im new to the forums! =D
Old Jun 23, 2011 | 05:43 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
remove bottom seat.....u should be able to slip it thru to the back
Old Jun 23, 2011 | 07:27 PM
do you know how exactly to remove the bottom seat and how to remove the carpet in the trunk to get to the rear sub
Old Jun 23, 2011 | 09:06 PM
Drewman752's Avatar
4gauge wire for power, and you can do 4 or 0 gauge for the ground. i ran my wire along all drive side floor looms. the wire then runs up were inbetween the head rest and the car pillar. there is a peice of foam you can take out, and its a small access to the trunk. from there just look were the top cover is in the truck*were you can access the back speakers, and they should pop out from there.
Old Jun 23, 2011 | 09:10 PM
Drewman752's Avatar
oh, get a capacitor to. i didnt i ran 1000watt, and killed my alternator in a matter of acouple months.
Old Jun 23, 2011 | 09:56 PM
Mafyoso's Avatar
Balling in the...
search the Threads cause they are pretty good DIY with pictures that help you do all of this.
Old Jun 24, 2011 | 02:24 AM
hp1kw's Avatar
Yank the grommet and punch the hole outside the engine compartment. You will have to punch through some insulation though to get to the pedal area. Four gauge is fine for power and ground. What amp are you running? If it is class D no need for a cap, if its a JL slash get rid of it and buy a more efficient amp.
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
SUPRMN84
Oct 7, 2015 09:46 PM
jmaxima03
Sep 27, 2015 10:22 AM
