power window problem?
My driver one-touch goes up fine. The passenger goes up about half way then goes down a bit then stops. I know there is a safety feature that will do this if there is something in the way, but it does it when there is nothing in the way.
anyone else have this happen?
I've had the car for about a week so far, and haven't noticed it except a few minutes ago in the garage.
it's an 07 if that matters
thanks!
thanks!
I'd check with the dealer.
My friend had the same issue, he went went to the dealer. They did a quick check and found it was the safety reset in the 'auto' function of the switch.
They hooked up their scan tool and did a reset of the power window system, then a re-initialization, then all was well again. NO parts were needed!
Hope this helps!
(I've heard there is a manual way to reset the system, but don't know the procedure...)
Cheers!
Hope this helps!
Cheers!
k6biv
09-10-2015 06:37 PM
ahsm
09-09-2015 08:35 AM
acura, automatic, initialization, initializing, malfunction, mdx, passenger, power, problem, procedure, rl, rsx, tl, window, windows
