Pos/Neg Factory sub wire identification
Old Jul 29, 2013 | 09:56 AM
Spence52490's Avatar
I'm in the process of installing a loc, so I can put my amp and sub in. I've found the stock sub wires I need to tap into but which one is positive and which one is negative?
Old Jul 29, 2013 | 11:30 AM
fcuked's Avatar
spoiled brat
SW+ Yellow w/Black
SW- Light Green w/Red
Old Jul 29, 2013 | 11:54 AM
Am I going to have to detach that clip to see the colors?
Old Jul 29, 2013 | 12:00 PM
fcuked's Avatar
spoiled brat
You either get a harness or cut the wires.
I just cut the clip off and connected it to the pos/neg on my loc.
Old Jul 29, 2013 | 01:45 PM
abirvalg's Avatar
if returning to stock may be needed get a Metra harness
if not cut them
Old Jul 30, 2013 | 09:11 AM
TL_Trell's Avatar
+1 ^^
Yea thats what i did. I spliced into the factory sub wiring with Quick Splice connectors Left the factory sub unplugged. worked out 1000X better than the people saying removing the entire back seat, factory sub, and covering the hole where the factory sub used to sit, etc. Besides i like everything i do to be easily reversible.
Since the signal is after the factory Amp you'll need to turn down the signal on your LOC converter so the sound isn't distorted.
Old Jul 30, 2013 | 09:27 AM
abirvalg's Avatar
careful with quick splice connectors
they can weaken or damage one or both wires and loose contact due to oxidation or loss of mechanical pressure
harness plugs or solder are much more reliable long term
Old Jul 30, 2013 | 09:28 AM
the harnesses are cheap on amazon
Old Jul 30, 2013 | 09:52 AM
TL_Trell's Avatar
what kind of harness would i have needed? I just needed to connect the Metra Line out converter to the Audio signal from the factory sub.
Old Jul 30, 2013 | 10:22 AM
abirvalg's Avatar
honda speaker
Old Jul 30, 2013 | 09:50 PM
alan_rich's Avatar
05 TL A-Spec
Probably a stupid question but what is LOC?
Old Jul 30, 2013 | 09:53 PM
alan_rich's Avatar
05 TL A-Spec
I want to put a audio system in my 05 TL in the most cost effective way and still keep my stock deck too. Does the way this post is explaining still need a amp or does it run off a stock one? I'm very new to this so sorry for the stupid questions but any help or advice will be much appreciated.
Old Jul 30, 2013 | 10:20 PM
TL_Trell's Avatar
LOC is a Line out converter. I'm not a genius on this stuff either but you will still need a Aftermarket amp as I don't believe the stock amp will be strong enough to power your subs.
Old Aug 1, 2013 | 01:42 PM
alan_rich's Avatar
05 TL A-Spec
Can someone please let me know what I would need to put a system in my car and still keep my stock radio. Besides the obvious like a sub and amp. Can I use any of the exsisting wiring and does the stock radio act as an amp for the stock speakers or is it amped separate?
Old Aug 1, 2013 | 01:46 PM
abirvalg's Avatar
please refer to FAQ for basics
Old Aug 1, 2013 | 02:06 PM
alan_rich's Avatar
05 TL A-Spec
FAQ is for questions about the website itself.
Old Aug 1, 2013 | 02:45 PM
abirvalg's Avatar
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/3g-tl-audio-electronics-faq-605299/
Old Aug 1, 2013 | 09:51 PM
TL_Trell's Avatar
you need the usual aftermarket supplies. Power wire, RCA cables, remote turn on wire, etc. Since you are keeping to stock radio you will need a Line Out Converter so you have somewhere to plug your RCAs into. im pretty sure everyone cut into the wires from the factory subs. i think some cut into it before the stock Amp and some after. I chose to splice into it after the stock amp with Quick Splice connectors and just tune the signal on the LOC. some people have some reservations about using quick splice but ive never had any problems with them.
Old Aug 1, 2013 | 10:26 PM
alan_rich's Avatar
05 TL A-Spec
@Trellz08 was there any hissing or unwanted noise from not going preamp and does the stock HU "sub" option when you push in the volume knob still control the aftermarket sub now?
Old Aug 2, 2013 | 07:21 AM
abirvalg's Avatar
there shouldn't be any noise, not in the lows anyways
your volume controls will remain functional
you may want to run a remote gain control for the sub amp, make it easier to set gains from inside the cabin
Old Aug 2, 2013 | 07:23 AM
TL_Trell's Avatar
Nope I haven't experienced any hissing or unwanted noise and yea you can still control the subs from the stock head unit.
Acura604
20
Aug 5, 2017 12:55 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Birdflunuggetz
ILX
Sep 28, 2015 01:14 PM
