PDX Amp Under Seat
Old Apr 16, 2009 | 08:47 PM
tbone587's Avatar
PDX Amp Under Seat
I am installing a sound system in my friends 2004 Acura TL and there isnt many spots to mount amps without doing custom work or a sloppy install. I was wondering if anyone knew if a PDX4.100 Amp would have heat issues if I mounted it under one of the front seats. There is very little space under the seat, but the amp will fit under there.. I know most amps require space around, but are these amps able to run in that tight of a space without shutting down? Please let me know asap.
Old Apr 16, 2009 | 10:11 PM
fade2blk's Avatar
personaly I would not put one in there, it will be very tight. might want to install it in the trunk next to xm radio or nearby. that amp will be much hapier there.
good luck.
Old Apr 16, 2009 | 10:39 PM
csmeance's Avatar
good luck.
Put it in the trunk, under the seat you have the possibility of A. The amp getting damaged due to the seat moving around B. the possibility of shorting or damaging wires that are under there and C. damaging the amp due to heat.
You will need a good amount of space to keep the amps cool, if you want something smaller, take a look at the smaller xtant amps, I believe kennedy is using one for his sub and he put it under the seat.
Old Apr 18, 2009 | 09:44 AM
tbone587's Avatar
Damn, I was really hoping to get away with it being under the seat. I dont have the amp yet, but maybe ill slide it under there to see how tight of a fit it really is.
Old Apr 20, 2009 | 12:21 PM
so cal eddie's Avatar
There is space behind the panels in the trunk to put amps. You could also put it under the seat, but you will have to cut the carpet and padding to flush mount it in there. These amps do not get hot. Ive played them hard for hours and they are still cool to the touch.
Old Apr 20, 2009 | 12:37 PM
jiggaman's Avatar
I spend 2 much time here
i have a PDX amp under each one of my seats in a TSX, they have been there for a while now and no issues.
Old Apr 20, 2009 | 08:01 PM
Spiritman's Avatar
Man of God.....
Cool
I have the Xtant 3.1 under my seat. I love it there in the winter. Never had any trouble with it, at all. Been like a little over 2 years now.....
Old Apr 20, 2009 | 08:17 PM
Trew's Avatar
They will be fine if they fit. Since it is open on the front and back it will allow for cross ventilation and heat can be moved away. Additionally, cold air stays low and hotter air goes up so that will help with cooling even more.
I don't play my system loud often, but when I do, my amps remain cool unless I pound bass for hours.
Old Apr 21, 2009 | 10:14 AM
King of Pain's Avatar
I have fried other amps in the past but my PDX amps can be pushed pretty hard and they will stay cool to the touch.
I agree with Trew. They should be fine if they fit.
Old Apr 21, 2009 | 10:39 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
my (2) PDX 1.1000 get HOT...
Additionally... there are air vents under the seat... just keep the AC on and they should remain cooled by the car's HVAC system
Old Apr 21, 2009 | 10:42 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Wherever you place them, the PDX amps won't have any heat issues.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
