Pdx amp owners...
Old Nov 14, 2008 | 10:05 PM
BukvaMan's Avatar
Pdx amp owners...
Where do you have your gains set...
i have a pdx 600.1 and 100.4. After doing the setup of the 3sixty i bumped up the levels to -3 and acording to that i adjusted the gain on my pdx's. with a 100 and a 50 hz tone to get 30 volts for the 600.1 and to get 20 for the 100.4.
on the 600.1 i even had to switch the input selction to 0.1-1volt to get the desired output. wonder why the signal on the 3sixty is so week while its suppose to be close to 5v.
on the pdx 400.1 i had to go half the gain to get 20 volts but it gives me a lot of hiss at zero volume control.
Old Nov 16, 2008 | 03:54 PM
pnut23's Avatar
You need to add a line driver to get the high volt ouput.The stock amp sends a weak singal.I use the one from zapco slbu and it took care of everything for me.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
