Open Trunk With Car Running
Old Oct 24, 2008 | 01:34 PM
Fred99x's Avatar
06 WDP TL Owner
Question Open Trunk With Car Running
I have a remote start on my 06 TL and I cannot open the trunk with the key fob with the car running. The dealer who installed the remote start indicated that this is a safety feature (for what?). I'm not sure, but I believe even the factory key fob will not open the trunk with the car running and the key inserted in the ignition. Is there a work around for this as it's a pain to have to shut the car off just to open the trunk.
Old Oct 24, 2008 | 02:06 PM
I hate cars's Avatar
Push the button on the dash.
Mine won't let me open the trunk with the keyfob when it's in the ignition.
Old Oct 24, 2008 | 02:12 PM
Fred99x's Avatar
06 WDP TL Owner
I have the trunk button disabled so that if anyone breaks into the car, they won't be able to open the trunk (I keep my golf clubs in the trunk).
Old Oct 24, 2008 | 02:17 PM
old coastie's Avatar
Not to be a wise a** but,
1. Load trunk.
2. Start car.
Old Oct 24, 2008 | 02:23 PM
It's annoying to me too. I keep mine in valet most of the time because of my subs back there and I've had to shut the engine off more than once to get into the trunk. I'm sure it can be done and I'm curious as well.
Old Oct 24, 2008 | 02:29 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
there is a work around...
Find the key fob transmitter under the dash on the left hand side of the steering column.... (it's basically behind the VSA/Mirror adjustment buttons) cut the yellow wire on it's wire harness....
Old Oct 24, 2008 | 02:31 PM
Nice!
Old Oct 24, 2008 | 02:57 PM
korrupted's Avatar
J35A8
Figures a guy from the Bronx would know how to do that!!
Old Oct 24, 2008 | 03:02 PM
Trew's Avatar
Thanks Rodney. I am definitely going to try this. I keep my trunk release disabled for obvious reasons. It gets annoying when I have to shut my car off and pull the key every time I need to make an audio adjustment or if I need something from my trunk while the car is running.
Korrupted: Your avatar made me laugh more than mine did!
Old Oct 24, 2008 | 03:36 PM
timmahh's Avatar
it's me, Alan Rickman.
You guys who disabled the push-button in the car... are remembering to lock the pass through right ?
Old Oct 24, 2008 | 03:49 PM
Trew's Avatar
Naaah. My sub box is right behind the hole so no one can reach or see anything in my trunk. Besides, I like to open it sometimes to let the air into the car from the sub hitting.
Old Oct 24, 2008 | 04:08 PM
Fred99x's Avatar
06 WDP TL Owner
Yup, pass through is locked as well.
Old Oct 24, 2008 | 06:51 PM
BlueTypeSGuy's Avatar
Does cutting that yellow wire enables the door lock/unlock button as well?
Old Oct 24, 2008 | 07:40 PM
Fred99x's Avatar
06 WDP TL Owner
The yellow wire appears to be the fused input from the ignition when it's in the On or Start position. Cutting this wire should fool the system indicating the motor is not running. Not sure what other effect cutting this wire will do. Probably nothing (I hope).
Old Oct 24, 2008 | 08:17 PM
rodneyc77's Avatar
I haven't tried it yet ... But according to the electrical manual... Eliminating the ignition input (yellow wire) should keep the module operational while the car is on... I haven't checked if there's anything in the actual ignition switch the disabled the key fob itself...
I'll try to test this myself this weekend....
Thanks Ed for the compliment
Old Oct 24, 2008 | 10:06 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
rod you are a genious in electronics... I just dont get it, I would try this but lets leave it to those who know what they are doing
Old Oct 24, 2008 | 10:38 PM
BrandonClaps's Avatar
the installer should have run the trunk output signal directly to the switch which is always active...
most likely they just used the CAN-bus to interface with it which wouldn't work while ignition is on.
Old Oct 27, 2008 | 07:36 PM
Fred99x's Avatar
06 WDP TL Owner
Cutting the yellow wire did not work for me. Trunk still would not open with either the remote starter key fob or the factory key fob. Guess I'll have to wire an output from the remote starter unit to the trunk unlock circuit.
Feb 25, 2020 09:57 AM
tonio
Feb 5, 2019 05:43 PM
iesu3423
Sep 29, 2015 08:04 AM
kuzdu
Sep 10, 2015 08:42 PM
jfman55
Sep 5, 2015 02:55 PM
