Open Trunk With Car Running
06 WDP TL Owner
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I have a remote start on my 06 TL and I cannot open the trunk with the key fob with the car running. The dealer who installed the remote start indicated that this is a safety feature (for what?). I'm not sure, but I believe even the factory key fob will not open the trunk with the car running and the key inserted in the ignition. Is there a work around for this as it's a pain to have to shut the car off just to open the trunk.
Push the button on the dash.
Mine won't let me open the trunk with the keyfob when it's in the ignition.
06 WDP TL Owner
I have the trunk button disabled so that if anyone breaks into the car, they won't be able to open the trunk (I keep my golf clubs in the trunk).
It's annoying to me too. I keep mine in valet most of the time because of my subs back there and I've had to shut the engine off more than once to get into the trunk. I'm sure it can be done and I'm curious as well.
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Thanks Rodney. I am definitely going to try this. I keep my trunk release disabled for obvious reasons. It gets annoying when I have to shut my car off and pull the key every time I need to make an audio adjustment or if I need something from my trunk while the car is running.
Korrupted: Your avatar made me laugh more than mine did!
06 WDP TL Owner
The yellow wire appears to be the fused input from the ignition when it's in the On or Start position. Cutting this wire should fool the system indicating the motor is not running. Not sure what other effect cutting this wire will do. Probably nothing (I hope).
Retired!!! ON TOP!!!
I haven't tried it yet ... But according to the electrical manual... Eliminating the ignition input (yellow wire) should keep the module operational while the car is on... I haven't checked if there's anything in the actual ignition switch the disabled the key fob itself...
I'll try to test this myself this weekend....![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Thanks Ed for the compliment
the installer should have run the trunk output signal directly to the switch which is always active...
most likely they just used the CAN-bus to interface with it which wouldn't work while ignition is on.
06 WDP TL Owner
Cutting the yellow wire did not work for me. Trunk still would not open with either the remote starter key fob or the factory key fob. Guess I'll have to wire an output from the remote starter unit to the trunk unlock circuit.
