OEM amp replacment
Old Aug 10, 2011 | 10:34 PM
cinobyte's Avatar
OEM amp replacment
Ill take the flames as deserved.. to many search results
I would like to replace the oem amp. seems previous owner replaced speakers.
I wanted to know what requirements i need in the amp such how many channels and such? (I need more power for the after market speakers)
where is the amp located?
do we have a wiring diagram?
Old Aug 10, 2011 | 11:41 PM
geekybiker's Avatar
Do you know if the previous owner replaced all the speakers, or just the fronts? There are a total of 6 channels, one being the sub. OEM amp is in the passenger kick panel. There is a wiring diagram if you search for "wiring diagram" in this section. Its even the title of the thread.
Before you go ordering stuff, try and find out the make/model of the speakers and which ones were replaced. Also check the kick panel to see what the wiring situation is. Look for modified wires in the harness there.
Old Aug 11, 2011 | 12:34 AM
RBeachTL's Avatar
There is actually a thread on the OEM amp.
OEM amp is a 6 channel amp 25W/ch for the front L,R,C and Rear L,R and 100 W/ch for the sub. The front components are run in parallel.
The amp is located in the passanger side kick pannel.
Old Aug 11, 2011 | 09:12 AM
jda123's Avatar
Dogmatic Dinosaur
You might consider buying a 4 channel. Use the front 2 channels for your front components and bridge the rear channel for a sub. The stock amp would likely be fine for the center and rear speakers.
You are likely going to need to know what speaker were installed.
Old Aug 11, 2011 | 10:05 AM
Trunk Monkey's Avatar
Coolest A-zine Member
Just to reiterate...
1. Take off door panel (super easy) and figure out what mids are in there. Same with tweeters in dash. Do you see a x-over anywhere? Maybe in the trunk or up under the dash or in the kick-panel?
2. Do you have an aftermarket sub or did he also replace the factory 8" with a different 8"?
Old Aug 11, 2011 | 06:59 PM
cinobyte's Avatar
damn not one person flamed me for not searching more... Thanks for all the info exactly what i was looking for.
Old Aug 19, 2011 | 11:33 PM
cinobyte's Avatar
Sorry guess i missed this....
Polk Audio DB651's in the doors and rear deck
10' Kicker sub with a Sony Amp.
I have not looked at it very close but they have power from battery to the trunk for the amp
Old Aug 20, 2011 | 09:10 AM
What sub is the kicker (comp, compVR, etc)?
What ohm-load is the sub? (4ohm, 2ohm)
What is the model # on the Sony amp??
Old Aug 20, 2011 | 09:46 AM
cinobyte's Avatar
All installed before I got the car so I am not sure exactly what the components are (may go look today) it was done by bestbuy im sure. At this point I am not sure I would even change them I just need a little more power going to the DB651.
I need a little more volume
mada51589
Jan 9, 2025 04:40 PM
AndrewS
19
Mar 14, 2024 06:59 PM
handsom-hustla
Nov 13, 2015 05:04 PM
yahelou
Sep 6, 2015 09:12 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
