Nexus Tablet Install Question
Old Sep 24, 2014 | 01:41 PM
big_mac65's Avatar
B-MAC
I am in the middle of installing a 2nd generation Nexus 7 to replace my navigation. However, I don't want to completely get rid of the navigation screen. I have cut out the compartments below the radio and plan on putting the navigation there. My question is for those of you that have moved the navigation screen/HVAC screen down there, how do you secure it to where it will stay put?
Old Sep 24, 2014 | 04:57 PM
triax37's Avatar
Holy Smokes! Have you actually put the screen down there, or is this a photoshoped image? I can't help you as I just installed a tablet to replace the Navi and fully removed the old screen, but would love to see the final product. Good luck! Bump for a creative project!!!
Old Sep 25, 2014 | 07:31 AM
big_mac65's Avatar
B-MAC
It's no photoshop and is possible. I've seen it a couple of times on different peoples rides. I know it's possible and I'm actually done with everything except mounting the screen itself. I have hit a brick wall though and don't know how to secure it in place where the storage compartments used to be.
Old Sep 30, 2014 | 11:02 AM
big_mac65's Avatar
B-MAC
Just finished everything. I figured everything out on my own. Sometimes it's just a matter of grabbing a beer and sitting in your car to think about what could be done. I noticed that there are two tabs sticking out on both sides of the navigation screen. I used that to secure it to the passageways for the rear AC vent. Just used some small L brackets and then secured the navigation screen to it. Here's the end product.
I have the 2013 Nexus 7 installed for those wondering.
Old Sep 30, 2014 | 12:24 PM
EvilVirus's Avatar
Awesome job
Would love to see some videos
Old Oct 3, 2014 | 01:59 PM
big_mac65's Avatar
B-MAC
Here's a quick video of this thing in action!
Old Oct 3, 2014 | 02:02 PM
are you using bluetooth to connect your music?
or did you use an aux cord?
and this is something that I want to do, as i have a 2013 Nexus 7.
Old Oct 3, 2014 | 06:18 PM
big_mac65's Avatar
B-MAC
I am using a FM modulator I had lying around so I could create an Aux input on my 2006 TL. I ran a USB cable to my Fiio E17 DAC from the tablet. From there the Fiio converts the sound to an aux cable that plugs into my created aux port to get the music.
You could use bluetooth but direct connect has always had a better sound quality in my opinion. I did drill out the AC buttons a bit so I could fit a OTG cable into the tablet since the 2013 Nexus 7 has its power socket soldered onto the motherboard directly.
Old Oct 4, 2014 | 05:15 PM
i thought OTG cable wouldnt work with the N7 2013?
im very interested in doing this.
i figured you would have to drill the a/c buttons a little bit
Old Oct 7, 2014 | 11:19 AM
big_mac65's Avatar
B-MAC
It works perfectly fine with a rooted Nexus 7.
Old Oct 10, 2014 | 10:38 AM
triax37's Avatar
As bigmac said, the OTG cable works fine. In 2012's version of the N7, the connection for the OTG cable is a little more flexible and you don't need to drill out the A/C buttons. In 2013's version of the N7, the connection for the OTG is positioned where you will need to create some additional space for the A/C buttons.
Old Oct 15, 2014 | 08:41 PM
Rhydon's Avatar
I've been looking and can't find the answer. I have a Nexus 7 (2012) arriving next week.
Is there a way to use the OEM bluetooth to use Google Now voice, or do I need to get the iSimple with bluetooth?
It would be easier to say "direction to blah blah blah" instead of typing it in.
Old Oct 15, 2014 | 09:09 PM
mzilvar's Avatar
Interesting idea. I played with trying to get an external microphone to work for a while and didn't get very far. I don't think it would work with the OEM bluetooth though, but would be interesting to see what the tablet would do when tethered to the OEM bluetooth and you tried to place a call through the OEM bluetooth, my guess is nothing.
You could clip off a bluetooth headset somewhere in the car and use that for voice commands and that would work just fine with Google Now. You can even give Google a keyword that you can say to activate google now, so it constantly listens for that keyword like 'Google' and then when it hears it it activates listening for a voice command. So you could say 'Google navigate to .........' and it would pick up and interpret the command and perform some of the actions.
I was able to get an external bluetooth headset to pair with the tablet and use it for voice commands for Google Now, that wasn't too difficult.
The problem arose when trying to place calls from the tablet via a service like GrooveIP or Talkatone, where the receive audio was complete garbage and the audio routing wasn't working properly in the tablet (everything would go to the headset and rcv audio was just static). I had the tablet making calls using Google Voice through GrooveIP or Talkatone, however my microphone input was garbage. Google voice has since changed their service so I don't think it can be used any longer with a third party app like grooveip or talkatone.
The internal mic is difficult to use, due to it being buried in the dash once the install is done. It works, but it picks up a lot of noise so the distant end can barely hear you if you place a call and voice commands have a difficult time interpreting what you say due to all of the noise, if they pick up your command at all.
I'm sure there are apps out there to make the calls work now, I just haven't played with it for a while.
Sorry for off topic, nice job OP.
Old Oct 15, 2014 | 11:45 PM
triax37's Avatar
Very interesting thoughts, mzilvar. I just press the microphone button in Google Now and it mutes the other sounds - then it hears me fine when I say "directions to work" or "weather" or other commands.
So Rhydon, if you just just use the Google Now microphone button, it should work as you described. You don't need to use the TL's microphone or any other hardware.
Old Oct 16, 2014 | 12:14 AM
mzilvar's Avatar
That's cool, yours probably picks up voice a bit better than mine for some reason. I should turn off the fan that's blowing on the tablet constantly and it'll probably work lol.. I did do that while trying to get it to function as a phone, just it was so hard for distant end to hear me while driving or even parked, especially while I had the ATLP quad exhaust on the car haha
Old Oct 16, 2014 | 08:21 AM
big_mac65's Avatar
B-MAC
That's what I do as well. Seems to work fine for me.
Old Oct 16, 2014 | 09:05 AM
triax37's Avatar
Ah yes, the fan. I know we PM'ed about that - my N7 worked great throughout Colorado's summer heat, without the fan (sitting unused next to me).
As for the voice recognition, I haven't tried to have it constantly "listen" for specific keywords like you mentioned - my guess is that it would struggle to hear/recognize those commands while music is playing. But, if I hit the microphone button, the music mutes and the commands seem to be pretty easily understood. Thanks again for all of your help!
Old Oct 16, 2014 | 01:55 PM
Rhydon's Avatar
Thanks for the response. I've just been debating on whether to get an iSimple with bluetooth, or just go the less expensive route and only get one with aux inputs.
I read somewhere that the mic was no good, being buried in the dash, which was why I asked. All I needed it for would be for commands (not calls). I can use OEM bluetooth for phone calls. Does the Nexus 7 respond to "OK Google" like the newer Androids?
I plan on upgrading to the Nexus 7 in the next couple weeks and will hopefully remember to document (pics/video). Just need to gather the supplies. Down the road, i hope to add a backup camera powered by backup lights and connected to tablet by A/V to USB converter. Then have an app run (then close) to show video feed when it detects the camera.
Anyone do something of that nature yet?
Old Oct 16, 2014 | 11:27 PM
triax37's Avatar
Re: "Ok, Google" - Like we've said, the Nexus 7 can be setup to constantly listen to commands, but the microphone may have a hard time hearing while music is playing.
Re: backup camera - I've covered this in my Nexus 7 install thread (below), including where to buy the converter.
https://acurazine.com/forums/audio-b...ctures-911259/
mzilvar's Avatar
If you load a newer version of android you can accomplish those things.
Autodroid is going to be your best bet, right now it has the best development support for the Nexus 7 and is located here:
[ROM][4.4.4][F2FS/EXT4] AutoDroid 1.2 | Nexus 7 | XDA Forums
Otherwise if you have the 2nd gen nexus 7 then I'd look into USB-ROM, but you have to pay for the 2nd gen version of USB-ROM. Autodroid is free, but is developed for the 1st gen version, I don't know what else is out there for the 2nd generation version.
Old Jul 3, 2015 | 05:13 AM
champaned_out's Avatar
sorry to bump such an old thread, but does anyone know how the OP managed to get the navi screen down there? i have a nexus 7 tab setup but from what i remember the wire harness for the ac/temp controls on the bezel cant reach all the way down to the store compartment.. OP's last activity was on the site was about 9 months ago so i dont know if i can get in contact with him.. anyone else with this setup that might be able to chime in?
Old Jul 3, 2015 | 07:51 AM
polobunny's Avatar
Registered Bunny
You extend all of the cables...?
Old Jul 3, 2015 | 11:55 AM
JMiles_T's Avatar
Solder longer wires onto the existing ones. Yes, all those wires.
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
