New sound system and hardwood floor ???
you heard it right im installing hardwood flooring into my TL. my father owns a hardwood flooring company and I wanted to see how it would turn out. i will list everything i did and how i did it thanks for looking !!
can someone help me upload picture ? lol
This should help you on how to post pics.
https://acurazine.com/forums/3g-tl-photograph-gallery-96/how-post-your-favorite-pics-avatar-556986/
Received 6,470 Likes
as we speak i am putting on the poly top coat and waiting for it to dry. the color is amazing and i wanted to know what kinda struts would work good? as i am making a some what door so i can access my wheel in case of an emergency.
heres the final product. i made a door so i can acess my spare tire if needed.
Hmmm......Interesting.
as we all know that our tl dont come with an RCA wire behind our head unit. as you can see this little block it is a stinger line output converter. it converts reg speaker wires into RCA so you can install them into your amp. as i had no more use of my bass subwoofer since it was making some weird noise i decided to cut into that wiring. positive to positive negative to negative. after you connect the wiring remember to heat shrink everything it adds more safety and peace of mind.
after you finish all the connections to this loc. your also going to need a remote turn off. " this turns off your amp when your cars off". its either you wire up a switch to manually turn it off.. or you can wire one end of the wiring "red" into the positive of the factory wiring"blue" and into the REM, located on your amp like i did.
It's not my favorite thing but not awful either. I'm just relieved, I thought the entire floor of the car was getting hardwood.
alright heres something new. enough of the trunk. still need my plexi glass and a few other stuff. i ordered a bass knob, a switch so i can rewire my fogs into, and also a voltage gauge. i bought a piece of abs and used gorilla glue. after it dried i mocked everything up and cut it in the placement. then comes the bondo.
You should uninstall the switch and bass adjustment knob from the panel. You won't be able to get a good smooth surface on it with those components in place. The gauge cup should be able to stay. The major problem from the components being in place is when you go to paint the panel.
Good luck
Good luck
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
TLDude876
12-28-2016 03:18 PM
09-15-2015 06:44 PM
