Need some pointers on installing amp/subwoofer
Old May 18, 2011 | 08:39 PM
mckeenml's Avatar
I'm using the stock HU. I already have all the wires needed except the LOC.
How do I hook up the LOC and how would I connect the aftermarket amp to the factory amp?
and where does the remote wire hook up to?
if anyone could help id appreciate it
Old May 18, 2011 | 09:48 PM
Joelito2983's Avatar
Dominic@n TL
Search is your freind!!!!
Old May 18, 2011 | 10:12 PM
Mckeenml, I see that you found Acurazine....this site is better than the other one, where I helped you..
Sorry, that I couldnt answer your PM earlier today, as I was busy at work.
What kind of amp do you have? does it have pre-amp outs? if so, you can connect this directly to the stock amp...which is located in the passenger kick panel.
if you dont want to do it that way, you can add a LOC.
which you would need to take out the stock sub, which will expose two wires. positive and negative.
hook the LOC to the corresponding wires....positive to positive and negative to negative.
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
Garcia85
Sep 23, 2015 01:24 PM
TxRzrBk
Sep 17, 2015 01:07 PM
