Need recommendations for a steering wheel control interface.
Old May 10, 2018 | 12:41 PM
Vantastic's Avatar
5th Gear
I am looking for recommendations to be able to use my radio and cruise control buttons on my steering wheel after I put in an aftermarket radio. I don't want to have to splice into the factory harness.
Old May 10, 2018 | 12:53 PM
guitarplayer16's Avatar
https://www.crutchfield.com/S-XhFiJX...l-Adapter.html
Old May 10, 2018 | 01:48 PM
Vantastic's Avatar
5th Gear
You have to splice into the factory harness with those. Not looking to do that.
Old May 10, 2018 | 02:48 PM
What harness are you using to install your aftermarket radio?
It may already have a wire coming out of it ready to install to the module so you don't splice into the OEM wires.
Old May 10, 2018 | 04:10 PM
Vantastic's Avatar
5th Gear
Metra 70-1721
Old May 12, 2018 | 09:56 AM
Vantastic's Avatar
5th Gear
I guess my question should also be will I even need one for the cruise control to work or are those interface modules only to make the radio controls to work?
Old May 12, 2018 | 07:05 PM
Nyordrms's Avatar
WDP Group!
cruise control should still work either way, but i don't think there is one for radio controls that u don't have to get into the factory wiring,
Old May 12, 2018 | 07:19 PM
Vantastic's Avatar
5th Gear
I'm just gonna put the new radio in and see what happens. Figured since I couldn't find anything about the cruise control that it probably isn't an issue. Ok. Thanks.
TypeAcura
27
May 4, 2017 12:20 PM
therealjgall
Jan 12, 2017 08:44 AM
baboya96
24
May 5, 2005 01:45 PM
LiQiCE
Mar 18, 2005 03:00 PM
agean
Mar 15, 2005 12:25 PM
