Need help with sub amplifier choices
Hey guys I need some help picking a new amp for my system, as my old Crunch USA amp finally died after about 12-13 years. These are running in sealed boxes in my 4Runner, didn't modify the TL's system as I didn't want to drop the money for the sound processor to get it to work for the spare sub's I have laying around.
Setup:
2 Audiobahn 10" AW1000Q
- power range 50-600 watts RMS (300 watts per coil)
- peak power handling 1,200 watts
- 4 ohm DVC
I am looking to run this @ 1ohm for 1200w RMS on a monoblock D class amp. My coworker was pointing me towards Soundstream RUB1.1600D which I saw they have a 1000w amp or the 1600w amp, but I'd rather go a bit higher in power and just tune the amp down.
I seem to be having a hard time finding info on decent brands for amps. Can someone recommend any good brands that I can find some true 1200-1600w RMS amps that are for a decent price ($150-250)?
Setup:
- 4 ohm DVC
Codename Duchess
Setup:
- 4 ohm DVC
Setup:
- 4 ohm DVC
Also, as a general rule of thumb I avoid 1 ohm. Just too much demand on a charging system in most cases.
If it were me and needed that kind of power I'd look at something that will do the power at 4 ohm. Either a beefy 2 channel bridged, or a good mono amp would be the direction I'd go. But You're going ot have a hard time fining a reputable amp that does that kind of power in that price range unless you look used.
No. You will not find an amplifier that does a legit 1000+ watts for two hundred bucks.
But the big question is which brand of amps should I look to versus who to stay away from.
Setup:
- 4 ohm DVC
Setup:
- 4 ohm DVC
I listen to all sorts of music from hip-hop, country, rock/metal. Not sure if this aspect matters for the amp or not. As I already have the subs running in a sealed box, but may rebuild the box to better fit the truck.
JL makes some excellent class D amps for the price. They're over your budget but you might be able to find a used HD750/1 for $300-ish. They pop up used all the time. They put out a legit 750w at any impedance and you'll probably find that it's more power than any $200 "1,000w" amp.
There are also the XD and JX lines which are class D.
You could always go with a ported enclosure so your subs would require less than half the power for the same output as you have now and go with a smaller amp. And before it's brought up, a proper ported box will sound at least as good as a sealed box.
About the TL, there's no processor required for a sub install. You just tap into the stock sub wires. Depending on the amp you use, sometimes you can run the factory sub wires straight into the amp and sometimes you need a LOC to drop the voltage down which is cheap. You still retain control of the subs with the stock headunit.
Be careful with the manufacturer box specs, a lot of times they're chosen to save space or for lots of output, not for sound quality. I'll model those subs when I get home to give more box size and tuning options. What are you looking for, sound quality, output, a compromise of both?
Hope this info helps! Let me know if you need more. I'll try to grab my tape measure before so head off to work and get some dimensions.
IHC - I checked the dimensions of the back of my 4Runner. Here are the max dimensions I could go.
Width: 40"
Height: 20"
Depth - I have an angled back seat where the depth of the angle is 8" over the height of 20" (top of the seat). So I could probably go about 8" of depth at the top with 16" of depth at the bottom, or deeper if need be. Which based on 3/4" MDF that gives it close to 2sq ft of space roughly.
Width: 40"
Height: 20"
Well the hifonics brutus amps are CEA complient. I have a 2100 watt brutus and i have no doubt that it is putting out its rated power. Gain is only maybe halfway up with no bass boost and it will make my 2 12 inch kicker cvx's stink and they handle 1500 watts combined. I have them wired down to 1 ohm and i blast them full volume everyday and its going strong for a year now. amp barely heats up. i say give the brutus a try. cant go wrong with it
I ended up just ordering the Sundown Audio SAZ-1200D amplifier, I'm going to run it @ 1 ohm for 1200W to the pair of sub's I currently have (rated @ 600w RMS). I also ordered myself a KnuKonceptz Kolossus Fleks 0 Gauge (OFC) amp kit as well as enough wire to do my "Big 3" upgrade (factory battery ground looks like a 6AWG wire, granted it's like 4 inches long, but still).
I now just need to figure out how the heck to build a proper box ported for these subs I have!
That is good to hear! I tried to do lots of looking and it seemed to be a good choice from what I was seeing.
It's always fun seeing all the shipping confirmations coming through from all the vendors that you bought some stuff through!
Registered Bike Offender
Yeah I've used one of their kits before and ordered 30ft of a couple of their speaker wires, can't remember the gauge, but the wire is absolutely awesome. Thick and flexible. You won't be disappointed.
Oh yeah, getting the shipping confirmations is awesome. Even better when the box is at your house.
This was my response to seeing the FedEx delivery exception email and then texting him asking him if he heard anyone answering the door and he said yes....
09-25-2015 06:14 PM
maharajamd
Console & Computer Gaming
09-24-2015 03:31 PM
4drviper
09-23-2015 09:00 PM
4drviper
09-23-2015 07:42 PM
