need help removing door panel
Old Oct 3, 2008 | 09:35 PM
kris10950's Avatar
i want to dynamat and install new speaker, have never taking apart door panel before,please show me how, and is there an caution i should keep an eye out for.
Old Oct 3, 2008 | 11:55 PM
modificata3's Avatar
07 TL type S NBP!
I think a dude w/ 240SX (along w/ something else in there) as his name did a DIY post on this...try to search it. It wasn't long back, probably like a month
Old Oct 4, 2008 | 10:51 AM
Trew's Avatar
It's very easy. All you need is a phillips screwdriver and a small pick. You will have the door panel off in less than 10 minutes.
Here's a link to another thread that may help you.
https://acurazine.com/forums/3g-tl-2004-2008-93/front-rear-door-panel-handles-wstrip-glass-window-regulator-removal-3g-garage-f-016-a-603296/
Tip: Be careful removing/installing the rubber grommet at the rear of the door panel. It may start to spin when you remove or install it. If this happens, place a flat head screwdriver behind the panel and press on the spinning anchor in the door behind the panel.
Old Oct 4, 2008 | 04:09 PM
kris10950's Avatar
hey, thanks. this would be my first project on my own
Old Oct 7, 2008 | 10:35 AM
CarrieLynn's Avatar
I also used the DIY that Trew listed, I installed the window roll up module so I needed to take the door panel off. Took less than 10 mins, EASY! GL
Old Oct 7, 2008 | 11:46 AM
LoveMyTL-S's Avatar
With the rubber grommet, I found turning the screw really slow helped. GL.
Old Oct 7, 2008 | 01:33 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
I've removed the door panels so much... I now blow on the screws and they come out... takes me less than 2 minutes to remove... but 1 minute is used up on the screw with the rubber grommet...
Old Oct 7, 2008 | 02:35 PM
wrxyboy's Avatar
1st TL-S on air in
why dont you just unplug the transmission sensor but the only down fall is you wont be able to tell how fast you going but if stops you from putting miles on the odometer. The computer wont be able to log any information if there is no signal going to it.
Old Oct 7, 2008 | 05:02 PM
Trew's Avatar
someone posted in the wrong thread. anyone wanna guess who?
I think you were trying to post here:
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/where-mileage-information-stored-our-cars-690644/
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
VA2000TL
Oct 2, 2015 08:26 AM
govtcheez
Oct 1, 2015 12:21 AM
CadiGTi
Sep 14, 2015 06:37 PM
