Need help with aftermarket head unit installation!!
so i deiced to install a after market double din (Pioneer AVH-P4000).everything plays and works but no sound is coming out from the speakers... i think its because the head unit needs to send a signal to the stock amp ? can anyone confirm this? if this is correct, what is the colour of the wire?
thanks in advance!
thanks in advance!
If you went straight to the speakers from the aftermarket HU, then it should play fine. Sounds like you have another problem. Check your radio manual for troubleshooting no sound issue.
you need to put in your signal after the factory amp since A. You need a remote to turn on the factory amp, and B. you are going to blow it up since the factory amp only accepts a very low voltage signal, like about 1 watt...
wow didn't know i could blow the factory amp up.. i guess i need to do a bit more research..
Soul_Deamon
Nov 13, 2018 04:44 PM
trinikidcl
Sep 4, 2015 12:56 AM
