Need Constant 12v Power
Can someone recommend a constant 12v power source from the fuse box at the driver's kick panel?
I'm installing an add-a-circuit and I'd like to know which fuse you guys recommend I tap from.
The source is protected by a 7.5 amp inline fuse, so it can't be using much current. I'd hate to have to run power all the way from the battery for such a small draw.
Thanks in advance...
check the power seat fuses, I believe that they have constant power. Another to check would be the window motors.
Power locks or seats would be my recommendation..
Just use the 20a as normal in the bottom of your windows are only on when the ignition is on or until a door is opened... add a fuse and a 7.5 in the top and good to go..!!
I used the Power Seat "slide" fuse. Can't remember what number it was. Worked just fine. I needed constant power to turn my disco ball 24/7 ![Teef](https://acurazine.com/forums/images/smilies/teef.gif)
Actually, my DVD player has a feature that allows it to resume at the last point if you stop and then restart the car. However, it needs constant power to retain the memory.
ikm19, I doubt there is a constant 12v source in the trunk. Even if there was, I wouldn't recommend tapping into anything there. Run a new wire from the fuse box.
Thanks Trew. One more question does Navtool require constant 12v or i can tap something in trunk.. i don't want to remove center console to access cigarette lighter plug. I am really bad in running wire.. i hope i can do it if i had to run wire or remove center console..
if you want more info, just pm me, sorry for the hi-jack.
Do yourself a favor and run the wire. I don't recommend tapping anything from the trunk, either powered by ignition or not.
Running the wire to the accessory power outlet in the console will only take you a few hours. I would recommend running a few more wires while you're in there just in case you might need them later.
it requires a switched power source, not a constant one. Running the wire is really simple, the easiest way to run it is using an add a circuit and the fuse box, then take the wire and run it under the kick panels to the trunk.
thanks guys... i end up running a wire from fuse box to trunk.. i read almost 20 DIY for dom install and i took like 3 hrs. But at the end i did it myself so it felt really good..
It would have never been possible without u guys.. thanks a lot.
SidhuSaaB
05-30-2020 12:40 AM
DerrickW
11-15-2015 05:52 PM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
