Navigation antenna?
Navigation antenna?
hi guys i have a quick question about the navigation unit. I own a non-navi TL and would like to instal the factory navigation system into my vehicle and I found a navigation unit but it does not come with any wires or antenna and I am not quite sure if it comes with the HVAC LCD screen, so my questions are: 1) Can I buy the wires and antena anywhere or will i have to buy it from the dealer? 2) If it does not have the HVAC LCD display where would I b able to locate one? Thanks in advanced guys I know i should hav searched but I have been really busy and my friend contacted me about this item and I really wanted the anvi for a long time now so I hope i can get some helpful advice. Thanks!
'04 6mt Pearl
Hope this helps.
If you need more info try this web site:
http://www.acuraparts247.com/sunnysi...catdisplay.jsp
I'd like to know more details about the nav system you purchased.
System Name / Component : NAVIGATION SYSTEM
001 39010-SDA-A41 DVD-ROM, NAVIGATOR
002 39540-SEP-A42 DVD UNIT, NAVIGATOR (ALPINE)
003 39541-SEP-A40 BRACKET, NAVIGATOR ELECTRONIC CONTROL UNIT
004 39835-SEP-A41 ANTENNA ASSY., GPS
005 90132-SV4-003 SCREW, ET (5X16)
006 91540-S0A-003 CLIP (96.9MM) 2
007 91601-SH3-013 GROMMET, SCREW (5MM) 4
008 93893-05008-07 SCREW-WASHER (5X8) 4
009 93901-25280 SCREW, TAP (5X12) 4
010 90627-SA5-003 CLIP, WIRE HARNESS 1
011 91655-SP0-010 SEAL A 1
It's the stock navigation unit that came off a 2004 TL, it's in good condition but the only thing is that it does not include the antennaand wires for it. Oh yea thanks a lot for the skematic.
Tha navi unit that I am trying to pruchase is something similar to this. https://acurazine.com/forums/showthr...=tl+navigation The site that you gave me wree actually pretty helpful, but the only thing it was missing was the buttons that go on the steering wheel (maybe it's there and I jsut didn't pick it up). And also the non-NAVI TL that have has only the time showing above the center A/C vents while as the NAVI unit displays the XM stations, and A/C. Without that I won't be able to know what temperature I'm putting the A/C on, so I need that piece.
You are going to have a lot of expense involved in putting a navi unit in a non navi TL. The electronics might seem easy, but it's the dash that's going to get expensive. You'll have to purchase and install all the components including the LCD screen buttons and trim around the dashboard where the LCD screen goes. It's going to be expensive unless you can find a wrecked navi TL in a junkyard and purchase the parts you'll need.
'04 6mt Pearl
Here are the steering wheel controls taken from the same web site.
001 06770-SEP-A80ZA AIRBAG ASSY., DRIVER 1
002 35880-SEP-A01 SWITCH ASSY., AUDIO REMOTE
Item numer 3 is the non-nav control switches
004 35890-SEP-A11 SWITCH ASSY., NAVIGATION GUIDE& HAND FREE TELEPHONE 1
006 35891-SEP-A11 CASE A 1
007 35896-SEP-A02 BULB 2
008 36770-SEP-A01 SWITCH ASSY., AUTO CRUISE SET 1
009 36773-SEP-A01 BULB A 2
010 36774-SEP-A01 BULB B 2
011 77901-SEP-A00 SUB-WIRE, CABLE REEL 1
012 78501-SEP-A81ZA WHEEL, STEERING (LEATHER) 1
013 78512-SDB-A61ZA CAP, BODY COVER 1
014 78517-SDB-A81 PLATE SET, SWITCH 1
015 78518-SEP-A01ZA COVER, BODY 1
016 78519-SDB-A81 PLATE, HOOK 1
017 78520-SDB-A81 DAMPER, STEERING 1
018 90134-S6A-A80 BOLT, HEX. (6X23) 2
019 90136-SF1-A02 SCREW, TAPPING (4X18) (NIPPON PURASUTO) 4
020 90161-SV4-003 BOLT, HANDLEBAR 1
021 93893-04012-07 SCREW-WASHER (4X12) 4
021 93893-04012-17 SCREW-WASHER (4X12) 4
022 93893-05016-17 SCREW-WASHER (5X16) 2
023 93911-25420 SCREW, TAP (5X16) 4
I have the same issue, well, somewhat... I have all the components needed (screen, ac display, HFL steering wheel controls, NAVI antenna, DVD-rom unit) with the exception of the bracket that holds the dvd-rom in place in the trunk. I too need all the wiring however. Are there any people out there in the NY area (will travel to you) that have the knowledge and skill to make a wire harness for the install?
'04 6mt Pearl
You will also need the clock display from a navi that has HVAC stuff built into it.
Would love to see your conversion as a step by step pictorial...hint hint.
I wonder if the factory recall will mean a brisk supply of NAV units.
Once I get the parts and everything I need, my friends (graduated with an EE degree ) will be doing the installation process so I'll b sure to take pictures and do a write up. Now all I need are the antenna and that HVAC display.
This thread about Non-Navi to Navi should be of interest to you and may help you out a bit.
yeah, read that thread... tried PM'ing the guy but no response... really wish he did the write up he was talking about, but oh well...
This is a big project, definately not something that you can just do on a saturday, which is why I want someone qualified working on my car. If I can't find someone soon, I guess my best bet is to go to the dealer, but I don't even know if they would do it, let alone think what they would charge for it.
navtool.com
31
11-16-2015 08:30 PM
us285126
10-02-2015 02:03 PM
