Navi reset on engine start- normal?
Old Apr 2, 2005 | 07:38 AM
subspace's Avatar
OK a dumb question from a new TL owner. I read the entire manual and there was no answer there.
When the ignition is switched to "I" or "II" (with engine off) the navi starts up, nag screen, press OK. I then programed the route I wanted. Then I turned the key from the "II" position to start the engine the navi reset, nag screen again, hit OK and it lost the route I had set, since I did not save it. Is it normal for the navi to reset on engine start? Why do I have to go through 2 of those horrible nag screen waits.
I guess I should just do all my route progamming with the engine already started, or save the route on the Todays Route screen. Not a big deal, just curious if this is normal or not.
Just an aside. I think the navi is great. I'm glad I got it.
Old Apr 2, 2005 | 10:32 AM
JT3's Avatar
JT3
Yes, it's normal for the navi to be reset during ignition. However, you shouldn't have lost your route.
If you program the route and you let it finish calculating, then when the navi resets, and you press OK, it should then prompt you to continue your last route. Even if you accidentally say no here, the route should be available through the menu screen by pressing the previous destinations option.
Old Apr 3, 2005 | 12:04 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
Yeah, this is annoying. If I didn't have to wait through the entire boot sequence and nag screen, it wouldn't be so bad. I think it's reseting because power to it is temporarily interrupted while the engine turns over. I wonder if a modification could be made to put a large capacitor across the nav's power to allow it to coast through the power interruption without reseting.
Old Apr 5, 2005 | 09:48 PM
04TLMan's Avatar
Red line...use it
I thought the same thing. But I wonder...if you notice, the headlights do not even dim at all when starting. This always happens with other cars. When you draw 80 to 100 amps for the starter, the voltage drops. Unless these new headlights do not react that way (then can handle a short drop in voltage).
Any ideas if these lights are different in that respect? If not, maybe they reset the NAVI by default to fix some problem....we do a reboot with windows machines all the time.
oyayjoe
Jan 1, 2019 10:17 PM
mugen_kid
Nov 13, 2015 10:38 PM
vbgregg
Sep 11, 2015 05:38 PM
HeloDown
Sep 8, 2015 06:51 PM
yahelou
Sep 6, 2015 09:12 PM
