Navi Problem/Question
Old May 18, 2009 | 12:19 PM
jgilbert84's Avatar
4th Gear
I have a 2005 TL with about 71,000 miles. I was looking at a new MDX for my dad this weekend and the salesman mentioned the touch screen nav. I made the comment that I wish my TL's was touch screen and he said it was. Well, sure enough, according to the owner's manual it is. But, ifI touch 'buttons' on my screen nothing happens. Is there a setting that turns off touch screen, or is my screen just screwed up? Anyone else ave this issue?
Old May 18, 2009 | 02:23 PM
CocheseUGA's Avatar
Well, do the on-screen radio controls work? How about the help menus?
Old May 18, 2009 | 02:40 PM
jgilbert84's Avatar
4th Gear
None of the buttons on the screen work by touching them. I have always used the toggle switch for typing in addresses or the preset radio buttons to change a station.
Old May 18, 2009 | 03:29 PM
csmeance's Avatar
are you under warranty? If yes, go to your dealer and have them fix it, the screen is about 3000 dollars!
Old May 18, 2009 | 05:55 PM
satl72's Avatar
8th Gear
I had the same problem with my last TL, never got it fixed.
Old May 18, 2009 | 06:14 PM
fade2blk's Avatar
two both of you or any one else that may have this problem.
here is something that you may try, now if you do not want to take it to the dealer and they can do it.
screen calibration is what I am reffering too.
Here are the steps.
1. Turn your car's ignition to ACC
2. wait for nav to load.
2. press and hold "GUIDE" "MENU" and "CANCEL" @ same time for approx 5 seconds to bring up the diagnostic menu.
3. monitor check
In that menu there are two more items that need to be checked
monitor calibration and touch calibration.
I am not saying that this will not work, but it is a worth a try to get your touch screen working.
it is possible that it is not sensetive enought or it is not calibrated to the touch.
good luck
Old May 19, 2009 | 12:59 PM
jgilbert84's Avatar
4th Gear
Update: Took TL to the dealer. Problem is the screen, car is out of warranty, so I guess mine will forever be a non-touch screen navi. Dealer said it would be about $3,000 to fix.
Old May 19, 2009 | 01:37 PM
fade2blk's Avatar
that sux man. you might want to look on ebay, or a local junk yard.
Old May 19, 2009 | 04:12 PM
csmeance's Avatar
there is a thread called too late to get factory navi a few down or up from this one. In it is an ebay link. Contact the guy there and ask him if you can just buy the screen for your car.
Old Jun 9, 2009 | 10:22 AM
jgilbert84's Avatar
4th Gear
update
So when I took it to the dealer, only the touch screen was not working. After they looked at it, the entire navi was broken. It worked fine prior to them looking at it, with the exception of the touch screen. After taking it back to them and speaking with the service manager, the dealer will be replacing the entire unit, free of charge. And I've put about 1,500 miles on the loaner car they gave me....TSX's are really slow!
Old Jun 9, 2009 | 12:33 PM
LoveMyTL-S's Avatar
Sweet! Can't beat an all out replacement. Glad things are working out for you.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
us285126
Oct 2, 2015 02:03 PM
jmaxima03
Sep 27, 2015 10:22 AM
Cgannotti
Sep 25, 2015 05:04 PM
