Navi Hack v3.30F Help
Old Nov 8, 2012 | 11:50 AM
TerpNation's Avatar
Exclamation Navi Hack v3.30F Help
I can't get this to work. Who here can help me. Here is what I have done:
Go to this link:
https://www.dropbox.com/sh/j6lm9msu9k7fpw1/-G1TpFV_ms
download the three files. Then burn JUST these three files onto a blank CD, does not have to be DVD. Be sure to finalize.
once complete, follow the instructions below:
2. Go to your car.
3. Turn your car's ignition to ACC
4. Open the trunk and pop out the NAVI disk (if it's in there)
5. Insert your newly burned CD.
6. Go back to the driver seat, the display will show some dvd read error, now press and hold "GUIDE" "MENU" and "CANCEL" for approx 5 seconds to bring up the diagnostic menu.
7. Wait another 5 seconds to let it load up completely. Press "version" button on the screen
8. Press "LOAD DISC" to load your custom bin into the navigation.
9. Wait until it's completely done and it will then display another error message about can't read the navi dvd, now take out your bin CD and insert your Navigation disc and you are done!
Old Nov 8, 2012 | 11:51 AM
TerpNation's Avatar
I finalized the CD.
I've been at this for months.
Old Nov 8, 2012 | 11:55 AM
Hope you can successfully get it working!
Old Nov 8, 2012 | 11:59 AM
Wacker's Avatar
:what:
What step is giving you issues?
Old Nov 8, 2012 | 12:07 PM
TerpNation's Avatar
Step 8.
I press the load disk. It doesn't download anything. It says check disk.
Old Nov 8, 2012 | 12:18 PM
Wacker's Avatar
:what:
I would suspect the burn is the issue. I used. CD-R and IMGburn. Burn as an iso image. I had the same issue using DVD-R. When I switched to cd it worked for me.
Old Nov 8, 2012 | 12:21 PM
TerpNation's Avatar
I just burned as iso image. same issue. i am using cd-r
Old Nov 8, 2012 | 12:37 PM
TerpNation's Avatar
Old Nov 8, 2012 | 08:46 PM
TerpNation's Avatar
holla at a playa...
Old Nov 9, 2012 | 01:38 AM
TerpNation's Avatar
a playa in need is a playa in deed
Old Nov 9, 2012 | 07:30 AM
TerpNation's Avatar
Old Nov 9, 2012 | 12:27 PM
Deelow's Avatar
Sorry brother, I wish I could be more help. I took the files given and using imgburn made them an iso. From the file the iso was in, I took the .img file and burned that to disk using burn disk image to disk (imgburn as well) and it worked for me. Maybe get a 3.5 disk load and use the same instructions. What year TL do you have?
Old Nov 9, 2012 | 01:11 PM
TerpNation's Avatar
2004
Old Nov 9, 2012 | 07:59 PM
TerpNation's Avatar
bump
Old Nov 9, 2012 | 08:08 PM
Deelow's Avatar
It's got to be the Navi disk bro. If you buy a 3.5 orange I bet it would work. See if you can get one off the BM. The only reason his files work for me is they are formatted for my disk version.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
SUPRMN84
Oct 7, 2015 09:46 PM
jmaxima03
Sep 27, 2015 10:22 AM
Cgannotti
Sep 25, 2015 05:04 PM
