multiple video signal adapter/switcher
Old Mar 29, 2007 | 12:32 PM
dennisil's Avatar
i tried to search the forum and found no results, and most stores only cary this product for home use and the units are entertinment center sized, i need a smaller alternative,
I have a DVD to nav converter and want to add more than one video source to it i hae seen some of you use 2-3 diffrent video sources, what do you all suggest?
Old Mar 29, 2007 | 04:02 PM
dennisil's Avatar
im going to answer my own question on here i guise
somthing like this but inexpensive is what im going for
Jensen Mobile Audio Video
Multi-Source Selector Switch KSW41
Old Mar 29, 2007 | 04:21 PM
havokgroup's Avatar
I have seen a bunch of different selectors at Radio Shack, Fry's, and even at Walmart. How many video source do you want to use? I recall a knob one that isnt too big for 3 different sources. I would check around your local electronics store to see what's available.
Old Mar 29, 2007 | 07:34 PM
YarrrTL's Avatar
I think there are a few members with that Jensen AV switch in their cars, and a few other members with the simpler RadioShack one. I've seen a lot on Ebay also just search: av switch or a/v switch or rca switch.
try these threads out:
https://acurazine.com/forums/ramblings-12/pc-case%85-do-they-make-what-i-want-140377/
https://acurazine.com/forums/ramblings-12/olson-twins-host-snl-140839/
Old Mar 29, 2007 | 07:52 PM
datmrman's Avatar
A lot of the a/v switches that are designed for the home will work in the car. These switches rarely require power so its a matter of finding one that is the right size and has the right number of outputs.
Since there are already two threads on this, please continue the discussion in any of those above threads.
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
rhdune16
Sep 28, 2015 11:31 AM
