Multiple Phones in one TL
Old Jun 22, 2005 | 08:10 PM
ekeefe's Avatar
3rd Gear
Hello,
Can the 2005 TL support 2 different blue tooth phones?
I am taking delivery 6/24/2005 and was wondering if the two driver memory settings also work with the blue tooth pairing. I would like the car to recognize both my wife's and my phone.
We are thinking of going with Motorola v551's.
Thank you in advance,
ED
Old Jun 22, 2005 | 08:14 PM
DEG's Avatar
DEG
It will support two phones, but will not allow both to be paired and in the car at the same time. Memory seat function does not apply to phone pairing.
Old Jun 22, 2005 | 09:13 PM
ntaylor's Avatar
I'm not sure what DEG means by "paired," but you can "pair" (as I understand the term--when you first set the phone up with the car) multiple phones with the car, up to six or something. You just obviously can't use two at the same time with the HFL. There was a guy who posted pretty detailed results about the behavior when you have multiple phones paired and two are in the car at the same time. I think he talked about how the car will pick up the first one detected, if it finds both it will recall the last one used, etc. but don't quote me on that. For the life of me, I can't find the friggin post, it was great detail. Sadly, only my wife's phone has bluetooth so it isn't an issue for me yet.
Old Jun 22, 2005 | 09:32 PM
crazymjb's Avatar
I thought it supported 6. Also, is there seperate memory functions for each fone?
Old Jun 22, 2005 | 09:43 PM
DEG's Avatar
DEG
HFL will allow up to 6 trusted devices (phones) to be established but will only connect (pair) with one at any instant in time. Any stored names and associated numbers are common to all phones used. No seperate memory functions for each phone.
Old Jun 23, 2005 | 06:40 AM
ekeefe's Avatar
3rd Gear
Hello,
Thank you for all the responses.
Any thoughts on the v551? Is this a good phone for the TL?
ED
Old Jun 23, 2005 | 08:10 AM
MeltdowN's Avatar
.....only connect (pair) with one....
Pairing only happens once, the first time you enter the code and add the phone to TL's HFL. After that happens, the phone is paired with the car. The connections established between the phone and the HFL, after that point, do NOT involve any pairing. Pairing is only related to the initial setup, where two devices add one another to their 'trusted' list of devices, following which, they do not need to perform service discovery or authentication (usually). The TL can be paired with 6 different phones at any given time, but can only be connected to one during usage.
Old Jun 23, 2005 | 08:25 AM
Scott in Houston's Avatar
Originally Posted by ekeefe
Hello,
ED
It's a great phone. I don't get a battery meter on it, but I don't care about that. I do get signal strength and all other functions work great. It sounds good and performs very well.
My answer: YES. It's a good phone for the TL.
Old Jun 23, 2005 | 10:06 AM
ekeefe's Avatar
3rd Gear
Hello,
Thanks for the v551 info.
ED
Old Jun 23, 2005 | 10:48 AM
crazymjb's Avatar
I heard the best introductory(cheap) bluetooth phone that will display everything is the SE. Although the RAZR has dropped in price significantly.
mlody
Dec 4, 2019 02:11 PM
datadr
Mar 23, 2016 01:39 PM
jpadilla
3G RLX (2013+)
Sep 27, 2015 07:53 PM
RenoTL
Sep 17, 2015 07:45 PM
