Low Aftermarket Amp Output voltage
I have a factory integrated system with stock radio, USA-Spec iPod integration, Factory amp > LOC > RCA > 4 ch amp. Upon trying to turn up the gains, the max voltage output I get is 2v. I changed my Amp > Ground > RCA > LOC > and bypassed the factory amp. Still only getting 2V at the aftermarket amp terminal with gains up. Someone said I need the factory amp to amplify the signal coming from the radio. But even after I bypass, I get the same low voltage as if the factory amp is still connected. Can anyone confirm this? Also, only thing left to do is to get a new radio. I need input because I have been without sound for about a month now, and I am getting annoyed. Thanks in advance.
So the output of the aftermarket amp is 2V?
What are you using for source material? Test tones?
2VAC is 1 watt into a 4 ohm load.
Or do you mean the preamp output level of your LOC is 2V? Because that is different, and shouldn't be a problem. Most amps have a gain structure that will allow for as little as ~.25V input.
First thing I want to understand is where, specifically are you measuring this. Second, does the output voltage change when you adjust the amp gain? Third, doulbe check that the input sensitivity is adjusted correctly too. The LOC should specify the output (in volts) and then you should adjust the amp input sensitivity to match the output of the LOC voltage range.
If you're truly measuring that low, then you might have a defective component somewhere.
To add, he LOC gain/sensitivity knob is half way. And this does not matter if it is turned all the way up either. So I am banking it is my factory stereo that is giving me problems. Especially since I still get low voltage when I pass the factory amp in the system.
This is the order of components in the system:
Radio > USA-Spec > Factory Amp > LOC > RCA > Ground for Aftermarket amp > Aftermarket Amp
Underlined components are what I have already changed to rule out.
Wow so you've done some swapping out already... Well clearly you know how to use a DMM. If you've confirmed that the factory amp and everything downstream is GOOD, then the problem is either the radio or USA Spec (I'm not quite familiar with this device...). Measure the radio pre-amp outputs to see what's happening there.
I'll check today. It should be a solid volt whatever it is since it is a solid test tone. I will try it at the pre-amp wires coming straight from the radio.
What is weird is that adjusting the amp gain has no affect on output. The only way that could happen is if there is no input signal to amplify. But you said it plays, just at really low levels right?
The stock radio preamp is 1.0VAC at max volume @1kHz. It is a balanced signal.
And what was the input condition that you measured 0.2V? Max volume?
I have a PAC SOEM-4 (4 channel). All tests are at 3/4 volume from my headunit. I don't want to clip and get a distorted signal. So my volume is at 30/40
That LOC has adjustable output levels. Did you verify that you can manipulate the output by adjusting the output levels on the LOC?
Also, to confirm, you are using the factory amp speaker outputs right? Because this LOC requires a MIN 5V input for low level signals which you won't get from the TL per JoeQuimby's info above.
Hi Ho: I expect that the problem lies in the way you are making the measurement, or rather in the way the data is being interpreted. First of all, a 2V rms signal across 4 ohm speaker is 1 watt rms. This is a very loud signal. (Most people set the output in a car at about 0.1 watts of so.) So, the most likely thing is that you have a supersonic (say 15 or 20 KHz) oscillation caused by probing or connecting something to the system that causes feedback.
That would explain why you get a large, stable reading while not getting much sound. If there is an oscillation, then something is likely saturating and that would tend to suppress the real signal. If you have access to an oscilloscope, connect it where you are currently making your voltage reading and see what is really there.
Pre-Amp:
wht/yel (Left Rear) .06-.07 VAC
org/red (Right Rear) .06-.07 VAC
grn/blue (Left Front) .04 VAC
gry/blk (Right Front) .03 VAC
Factory Amp Output:
Green: 2.3 VAC
Purple: 2.3 VAC
Grey: 7.7 VAC
White: 8.2 VAC
__________________________________________________ __
After passing through LOC:
All channels no more than 1.8 VAC
Now the question is, why is my LOC diminishing the voltage by that much? Given my radio isn't at spec, but the LOC is looking terrible right now. IMO....note this is all conducted at 40/40 volume with 1khz test tone playing.
maybe instead of buying a new LOC to test, get a line driver (Rockford Fosgate BLD for example) and hook that up pre-amp and see where you results go. If it works, that's the cleaner approach anyway.
1.8VAC on the LOC outputs seems normal to me. Does it go to 0V when you reduce the volume to 3/4? Did you try adjusting the LOC to see if the output level changed? I think there is something fundamentally wrong with this setup or a defective component somewhere... As someone mentioned above, there might also be something wrong with your measurement technique, but I wouldn't expect you to have an oscope just chillin in your garage. What kind of amp is this anyway?
Using a line driver is a good suggestion.
That's the whole point of the LOC. It converts the high-power speaker level signals to low-power line outputs. That's why it's called a Line Output Converter lol.
Honestly, the way I'd set this up from the jump is to take the factory preamp signal right into the amp (provided your amp will play nice with the balanced signal). No LOC. The 1.0V output of the factory preamp is at MAX volume. Your volume scale is not linear it's kind of an exponential scale so I would totally expect the output voltage of the preamp to be well under .5V even at 3/4 volume on the actual number scale displayed on the radio. I have not tested the actual voltage as you turn the volume down, just at the max levels, which are un-clipped BTW. But to give you an example, an aftermarket Kenwood radio with a 4 volt output that has a volume scale of 0-35 will look something like this in regard to volume and voltage:
Volume Voltage AC
35------------4
34------------3.6
33------------3.1
32------------2.5
31------------1.9
30------------1.3
29-------------.7
Etc.....
So at volume 17 (1/2 on the numeric scale) you may only see .1V.
You wouldn't want a linear voltage scale. You'd need like 500 steps for it to function right. (unless you are talking analog control, which we aren't, which is a whole different animal)
What amp are you running? Also, is this a new problem or has it never worked right since the amp was installed?
Volume Voltage AC
35------------4
34------------3.6
33------------3.1
32------------2.5
31------------1.9
30------------1.3
29-------------.7
Etc.....
The factory preamp can't go lower than 0V because physics and math.
Volume Voltage AC
35------------4
34------------3.6
33------------3.1
32------------2.5
31------------1.9
30------------1.3
29-------------.7
Etc.....
Volume Voltage AC
35------------4
34------------3.6
33------------3.1
32------------2.5
31------------1.9
30------------1.3
29-------------.7
Etc.....
I am running the Pioneer GM-8604 4ch D class. This is all coming from my system at one time making a loud whining noise (while no radio on) and frying my original amp. Things haven't been right ever since. Here is the full story on another website: http://www.stevemeadedesigns.com/boa...-channel-pics/
Just a friendly suggestion. You might want to try answering some of our questions too.
What kind of amp are you running? Is this a new problem or has this never worked? How are you taking the measurement?
My bad!!! Now I feel like a douche hahaha.If it were me, I would tune at 40/40. But it sounds like (assuming your measurement techniques are good), that it is in fact a bad head unit.
I finally fixed the problem! You can't tune an amp if the headunit isn't at max power without clipping. Thanks for all the help guys. But I now have another problem LOL. I will start a new thread.
