Loc install??
Old Feb 23, 2011 | 09:13 PM
Joelito2983's Avatar
Dominic@n TL
Loc install??
Ok so i have been searching for the past 2 hours and haven't found what i was looking for...
Im trying to find out.....where do you guys install the loc???
Ive been trying to find pics or info on where does the loc go??
Can anybody help?
Old Feb 23, 2011 | 09:50 PM
jda123's Avatar
Dogmatic Dinosaur
For what channels? Front, subwoofer or what?
Old Feb 23, 2011 | 09:54 PM
Remove factory sub.
will expose 2 wires, positive and negative.
Take the LOC and wire it up to those wires.
Old Feb 23, 2011 | 11:31 PM
Nick337's Avatar
Remove factory sub.
Easiest spot right there.
Old Feb 24, 2011 | 12:31 AM
Trunk Monkey's Avatar
Coolest A-zine Member
Easiest spot is right near factory sub. Mine is in the passenger side kick panel where the factory amp is. I tapped into it right after and the LOC fits perfectly snug in there.
Old Feb 24, 2011 | 06:27 AM
Dominic@n TL
IM trying to do a whole systems upgrade with 3 amps in total....so which loc do i really need????
Old Feb 24, 2011 | 06:28 AM
Dominic@n TL
Most of you guys dont sleep right?????
Old Feb 24, 2011 | 06:44 AM
1islandparadise's Avatar
I done a mini diy in a thread. If you need more info, shoot me a pm. If you have a type-s you have to disconnect the rear microphone for the noise cancellation system also....
subwoofer install help!
Old Feb 24, 2011 | 07:57 AM
Dominic@n TL
Thanks!!!
Old Feb 24, 2011 | 08:44 AM
jda123's Avatar
Dogmatic Dinosaur
If you want to do the front and rear channels, then you will need to tap into the wires in the passenger side kickpanel. Pre amp is about a 1V signal that is mostly flat and full range. Post amp is crossed some and is also about 1V or so. There are wiring diagrams on here where you can find the colors of the wires.
Old Feb 24, 2011 | 10:47 AM
Originally Posted by Joelito2983
Thanks!!!
No prob! Check out our 3G Garage for a list of more DIY's...
FAQ for 3G TL Newbies.....
Old Mar 3, 2011 | 11:24 PM
badteddy's Avatar
my LOC's were installed right by my amp. is that a bad thing?
Old Mar 4, 2011 | 08:59 AM
Mr3lite's Avatar
I put my LOC in the passenger kick panel to the factory amp...
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
alan_rich
Sep 7, 2015 11:08 PM
