Lg8600
Old Nov 17, 2006 | 11:23 AM
Hawhyen51's Avatar
Lg8600
Anyone got this phone?
Old Nov 17, 2006 | 11:47 AM
Shalooby's Avatar
Secret Agent
I have the 8300. Works flawlessly. Shows Signal Strength and Battery level in the MID.
Old Nov 17, 2006 | 01:31 PM
Hawhyen51's Avatar
I know about the 8300. I thought about the Chocolate (8500), but I didn't like the idea of a sliding numeric pad. The 8600 is a newer version, looks similar to a V3 and has micro SD slot for music. I got a chance to upgrade for a lot cheaper than I thought. Wanted some opinions before I decide. I know Howard forums has an entire section about it but wanted opinions from someone who has paired it with our cars. Thanks anyway.
Old Nov 17, 2006 | 03:09 PM
Laxplaya11385's Avatar
I have it, and LOVE it. What did you want to know?
Old Nov 17, 2006 | 04:26 PM
Hawhyen51's Avatar
Any probs with pairing, dropped calls with HFL?
Old Nov 17, 2006 | 05:10 PM
nope! everything works perfectly. Shows signal strength, and battery life. It kinda makes a "cackling" sound when you start making your call, but it stop before you hear the 1st ring. That's the only thing that i could think of that would be a problem.
Old Nov 17, 2006 | 11:59 PM
Hawhyen51's Avatar
Cool - thanks!
Old Dec 3, 2006 | 12:21 AM
MWAgetawayride's Avatar
lg8600
when i make a call from my phone"8600" it doesn't transfer to the car automaticly. i have to transfer the call manually. also my phone book doesn't transfer to the car. it says that my phone doesn't support this feature. can anyone help.
Old Dec 3, 2006 | 12:49 AM
can you be more specific?
Do you mean that when you are on the phone already, and get into the car, you can't transfer the phone call to the car? In that case, i don't think you can, b/c i can't.
Also, w/ regards to transferring the phone book, you have to do it via the way the service manual describes it. You have to do it one by one. Then again, i have an '05 TL. I'm not sure if the '06-07s have that feature (ability to transfer the whole phonebook to the car).
Old Dec 10, 2006 | 09:28 AM
no, when i dial a phone number from the phone in the car. the call stays on the phone and it deosn't go to the car unless i press transfer on the phone.
Old Dec 13, 2006 | 06:28 PM
jkim23's Avatar
pairing instructions
can you guys give pairing instructions for the lg vx8600?
Old Apr 2, 2007 | 10:07 PM
trancemission's Avatar
Regions Leader
Well I have this phone. So far I cant answer received calls... Everytime I get a call and I hit the button to answer it I see the HFL blink and the radio comes back on..
I look at the phone and its still connected. They can hear me and my radio. But I cant hear them. I have to manually connect it.
I checked the HFL support site and it looks like this phone is not compatible....
Old Apr 6, 2007 | 08:14 PM
RjS's Avatar
RjS
Do you have the HFL set to "ring" or "voice" notification for an incoming call? If it is set to voice switch to ring and it should correct this issue.
Old Apr 6, 2007 | 08:38 PM
abracc's Avatar
I have the LG8600 in my 07 TL-S. The phone book does not transfer over and you have to manually enter the numbers into the address book on the navi and then dial from there. I cannot get it to dial out using the voice command. I can recieve calls perfectly though. Sometimes the caller id pops up and sometimes it doesn't...for the same incoming #. I emailed the folks at HFL support and they said they will not be making any updates to the HFL to have the LG fully functional. They said
"We have a very rigorous testing procedure and unfortunately, the VX8600 did not pass our testing for compatibility with HandsFreeLink. There were too many
issues with the phone.
We are only able to provide support for the compatible phones listed on
HandsFreeLink.com. The phone has to have Bluetooth and a "handsfree" profile
and to have passed our testing in order to be compatible. A "headset" profile
is not compatible with HandsFreeLink. We do not have any other knowledge
regarding this phone or have any troubleshooting tips. "
Anyway, they won't do anything more than they already have basically....
Old Apr 9, 2007 | 12:46 AM
paz840's Avatar
i've had the exact same problem
it sux b/c everyone who calls you can hear what you're listening to on the radio
i'll try switching the HFL to ring...hopefully that works!
Old Apr 23, 2007 | 06:05 PM
MNP's Avatar
MNP
LG 8600 Won't take Pauses
I just got an LG 8600.. it seems to work fine with my 04 TL, but when I call a number with built in pauses, the call terminates immediately. The message on the phone itself is that the call failed. Is there any way around this or am I going to have to return this phone. Thanks
Michael
Old Apr 30, 2007 | 09:58 PM
unr1's Avatar
this thread has conflicting responses...
does the LG VX8600 work or not?
If it does work, any advice on how to pair and use it?
Old Apr 30, 2007 | 10:53 PM
unr1's Avatar
Does the fix the problem for any of you guys? I would appreciate any feedback.
Old May 1, 2007 | 12:13 PM
unr1's Avatar
bump, anyone?
Old May 1, 2007 | 12:31 PM
Regions Leader
no it doesnt.
the phone sucks with our cars
go here and look it up. acura even says its not compatable
http://www.acura.com/models/handsfreelink/hfl_home.asp
Old May 1, 2007 | 01:14 PM
mrhenchen's Avatar
the phone itself is good but not great. the numeric pad is flat so its hard to get a feel for what you are pressing which leads to hitting the wrong number or letter key. the phone is sleek and slim with a pretty loud music player. one flaw is the speaker phone, a lot of people complain at how low the volume is when it's on speaker. the phone works with the HFL but doesn't seem to transfer your phone book, only answer/end calls and shows the number Not name of the person calling or dialing out. you can also add names into your phone book manually and state the name you wish to call.
Old May 1, 2007 | 01:29 PM
unr1's Avatar
thanks guys
time to trade the phone...sigh.
Old May 1, 2007 | 01:38 PM
Regions Leader
Originally Posted by mrhenchen
the phone works with the HFL but doesn't seem to transfer your phone book, only answer/end calls.
I cant get it to answer calls. Thats my problem...
Old May 1, 2007 | 01:57 PM
unr1's Avatar
on the HFL website, it says "Incoming calls" are fine but "Handsfree" does not work.
Not sure exactly what that means.
So changing from voice to ring as mentioned above didn't work?
Old May 2, 2007 | 02:41 PM
unr1's Avatar
bump
so let me get this straight....
-you CAN answer incoming calls
-you CAN'T make outgoing calls? (there is no way to do this? ...no navigation in my TL)
-you CAN'T transfer calls from phone to TL or TL to phone
anyone?
Old May 2, 2007 | 03:38 PM
DustFreeVinyl's Avatar
Brake dust is a badge
Originally Posted by unr1
bump
anyone?
I have this phone and it works just fine. I can answer incoming calls, make outgoing calls, and transfer calls from the TL to the phone. It also displays the phone number, signal strength, and battery life in the MID. You might want to try dialing *228 and updating the software on the phone (press 2)...that might help out a little. And disable the "You have an incoming call" voice when you receive calls. Hope that helps.
Old May 2, 2007 | 07:39 PM
unr1's Avatar
Wow, great news!
Are you sure it is the EXACT phone pictured earlier by TranceMission? (LG 8600)
By the way, *228 does not update firmware of the phone. That has to be done through data cable (maybe bluetooth can also).
That updates like roaming things or something like that.
May I ask the firmware number on your phone? (it's probably under settings > phone info) something like that.
Old May 3, 2007 | 08:51 AM
Yes, I have the LG VX8600. *228 updates the software...I didn't say firmware.
There's no firmware version in the phone info but my software version is: T86VZV02
Old May 3, 2007 | 10:14 AM
i've had the phone for about 6 months now, and I've had no problems. The only thing i can't do is see the name displayed in my MID when i send or receive calls. I do, however, see the numbers displayed in my MID when sending/receiving.
My software is also T86VZV02, and I haven't updated the software. I've had it since the 1st day it came out.
Maybe the bluetooth in the car needs to be updated?? (i have an' 05 TL, so maybe those w/ '04 are having the problems)
Old May 3, 2007 | 12:05 PM
unr1's Avatar
Thanks guys.
Old May 3, 2007 | 08:02 PM
unr1's Avatar
May somebody confirm what incompatible features are NOT correct on the Acura HFL website below?
Include your car model year please.
We can then update the sticky with better information.
Old May 3, 2007 | 09:03 PM
Regions Leader
well so far I turned off the voice and it seems to be working. Ive called myself from my home phone 3 times in a row and it seems to connect fine.
I gotta admit I wasnt really expecting this to work. Ill keep you updated....
Old May 4, 2007 | 08:11 AM
paz840's Avatar
i have an '05 and i still have problems
how do you turn off the voice, or switch from voice to ring?
Old May 4, 2007 | 07:59 PM
Regions Leader
you have to go into the settings of the HFL and she (or he, whatever you're in to) will guide you through it.
the only thing is now I dont get any ring or anything, my radio just shuts off but its cool I can still hear my phone go off. But so far its working.
Thanks for the advice guys....
Old May 8, 2007 | 11:33 AM
Regions Leader
I must thank you for the advice. I was about to get rid of this phone.
Changing that setting worked like a charm.
Old May 10, 2007 | 08:32 PM
unr1's Avatar
First hand experience with LG 8600 on 2007 Acura TL...
I just experimented with the LG 8600 and Acura HFL
Unfortunately I had problems with outgoing calls.
-Incoming calls work fine
-Outgoing calls work sometimes. (For some reason the HFL goes through the phone instead of the car and "transfer" does not work)
So basically sometimes the phone sound goes through the HFL and sometimes through the phone. And most of the time you can't transfer, I haven't figured out why though.
Any thoughts/advice?
Old May 11, 2007 | 04:24 PM
unr1's Avatar
bump
anyone...?
Old May 13, 2007 | 10:26 AM
Regions Leader
dude i think you're shit out of luck.
Acura openly admits that the phone is not compatible, so its hit or miss
Old May 13, 2007 | 11:32 AM
unr1's Avatar
Yeah, I guess.
The thing is it was working fine all day the other day so..
At least it works sometimes I guess
Old May 13, 2007 | 12:43 PM
Regions Leader
with mine, I deleted the bluetooth and added it again. Sometimes it answered and sometimes not.
But I changed that one setting and it works wonderful not. Try reestablishing the bluetooth...
