iSimple low Volume
Old May 24, 2015 | 01:13 AM
3GTLOwns's Avatar
iSimple low Volume
For anyone with an iSimple, is your volume low? I have an iSimple ISHD571 and I have to turn my volume up to or close to 40.
Old May 25, 2015 | 10:26 PM
jimmyfu's Avatar
Try turning the volume up on your phone as well. If it's low that's probably why volume through the iSimple, or any other similar device is like that.
Old May 29, 2015 | 07:34 AM
Rhydon's Avatar
It could easily be the device which is giving you volume issues. When I connect my Galaxy S6, it needed to be at 33 for good volume with the windows down at 45-50mph. When I'm listening to the Nexus 7, 24-25 is usually all it needs. That's windows down at 70mph.
Old Jun 1, 2015 | 11:10 AM
marxw13's Avatar
Im having the same issue. Im a professional car audio installer and I put a isimple IS32 in my 05. Regardless of the phone I need both volumes maxed out and its still not nearly as loud as the tuner. My solution will be to install an Alpine power pack model KTP 445 (about $150). This small amp has a front and rear gain adjustment and allows you to increase volume to the speakers. The downside is you would need to turn down the volume if you switched between Isimple and other sources.
Old Jun 1, 2015 | 10:23 PM
jimmyfu's Avatar
Well I don't suppose it would just be not pushing the connector in all the way, would it...? They are quite tight when only halfway in you know
4drviper
Apr 23, 2025 07:13 PM
08KBP_VA
Oct 22, 2019 01:55 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
Rcelestino93
Sep 23, 2015 10:01 PM
