iPod integration into 2005 TL
Old Nov 12, 2010 | 07:29 PM
TLTrance's Avatar
AVB for President!
Dammit, wrong thread. Mods, please move this for me to the Audio subsection. Thanks!
Yes, I've searched the 3G Garage on iPod integration, but it appears that the latest post is from 2006, so now that it's 4 years later, let me ask a very basic question:
What is the best option today for integrating an iPod using the connection from the bottom of the player? I have a navi unit and I would like to retain all OEM features.
Old Nov 12, 2010 | 08:28 PM
unctarheel003's Avatar
I have an 05 as well with navi, and I got an iSimple, it works flawlessly for me. It even shows the title of the song along with the artist on the screen and my ipod stays in the glove compartment and everything is controlled through the nav buttons and steering wheel.
And heres exactly what i bought.
Old Nov 12, 2010 | 11:23 PM
vuuha05's Avatar
^^^ yep yep. well put. plays music and charges your iphone..not much more to ask for.
Old Nov 13, 2010 | 12:02 AM
riplee's Avatar
AMFTW
how difficult was the install?
Old Nov 13, 2010 | 06:07 AM
voigt's Avatar
Maybe I'll have to give this a go. Although I have not done anything for six years why start now.
Old Nov 13, 2010 | 07:14 AM
NBP-UA6's Avatar
so what did you do? buy the thing and connect it via AUX port?
Old Nov 13, 2010 | 07:32 AM
VQPower37's Avatar
i think you have to connect it behind the headunit. so you will have to take apart the dash a little bit
Old Nov 13, 2010 | 08:57 AM
mikedog4's Avatar
Why me??
I installed the same unit, works great most of the time. Sometimes when I press the 6 preset and scroll it will never take me to artist and leave me stuck in the genre or playlist section. Sound quality is perfect though
Old Nov 13, 2010 | 09:20 AM
blkaspec's Avatar
Full of water...
Can you still see XM text ( artist and song) or is that function gone? I know some of the earlier models made you choose one or the other.
Old Nov 13, 2010 | 11:47 AM
I had BestBuy install it. It costs 160 for everything including installation. I don't believe it was that hard to install as it took the guy only an hour to do.
Yes, you have to take the dash out and connect it in the back.
Unfortunately, yes you do lose the XM function. I never used it so it worked out perfectly for me.
Old Nov 13, 2010 | 04:14 PM
cicacci2190's Avatar
First of all, do NOT let Best Buy even open your door, let alone install anything into your car. They do not do good work, and in fact, when i was getting my iPhone integration installed they messed up my radio which led to a long insurance claim.
Now, with that out of the way, I would just do a simple Pie X3. Look up elegant type s. He has an iphoen iontegration that you can tailor for an ipod install instead. Really opens up options if you ever want to add video and so forth.
But, just DEFFINITLY dont let best buy install anything for you.
If you have any local homeless folk, let them try to install it before you bring it to best buy, you'll probably get better results.......
....I think you get the picture. Good luck!
Old Nov 13, 2010 | 06:19 PM
eduardmc's Avatar
Acura TL 04, G37s 19"
i'm doing my installation of the isimple 571 tomorrow. will be taking my dash out. If i don't stress out i'll take some pictures. i have taking my dash out to fix my radio but it was a pain, i whish i had it at that time but doing it again it will be the same nightmare all over. I would not pay any shop EVER to remove my dash
Old Nov 14, 2010 | 01:00 AM
Maybe you just have had bad luck because Bestbuy installed my iSimple and it worked perfectly. In my old car, they installed an aftermarket head unit without any problems, and they also installed my friends sub and amp without any problems after a year. Two different stores, two different experiences I guess..
Old Nov 15, 2010 | 09:46 AM
mikedog4's Avatar
Why me??
Did you buy the seperate harness for the vehicle? My xm functions still work perfectly. I hit xm button and then scroll
using the tuner knob between sat-aux1-aux2-ipod
Old Nov 15, 2010 | 10:51 AM
blkaspec's Avatar
Full of water...
But can you see the text for both? That was my original question.
Old Nov 15, 2010 | 01:43 PM
scottn3's Avatar
Scotch
Do you know how it connects to the head unit?
Old Nov 15, 2010 | 04:17 PM
mikedog4's Avatar
Why me??
yep, can see both name and title for xm and ipod whenever that source is selected just like stock
Old Nov 16, 2010 | 09:17 AM
blkaspec's Avatar
Full of water...
nice, thanks!
Old Nov 16, 2010 | 09:21 AM
blkaspec's Avatar
Full of water...
You have to get behind the unit, usually through the drivers side footwell area. You have to remove the silver trim and then remove the plastic area that runs along the center stack. you then have to disconnect the XM plug and plug in the Ipod Y-cord, then insert the XM in to that. Button everything back up and you are good to go. Not hard, but you must be patient. Best done when the plastic is warmed up a bit. DIY found in Garage section.
Old Mar 14, 2013 | 01:46 AM
joeyboy248's Avatar
i have this also in my tl but its just not good enough the radio my opinion does not sound well
Old Mar 21, 2013 | 10:31 PM
fbatzaz's Avatar
3rd Gear
isimple aux system
I did purchase a isimple sys, but I dislike it does not come with a board, you have to deal with cables and hide your ipod
Old Mar 21, 2013 | 10:33 PM
fbatzaz's Avatar
3rd Gear
handsfreelink
I tied to set up my bluetooth like the manual says but I never had a response voice, whats wron with this, a module? or is it related with the update with nav system
4drviper
Apr 23, 2025 07:13 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
TLguy42
Sep 26, 2015 11:27 AM
