Invisicord for radar detector into rearview?
Old 07-01-2014 | 10:05 AM
ShaneN.'s Avatar
I want to hook up my V1 in the car and I have an invisicord here as well but I can't seem to find anywhere on the net that tells me where the prongs go into the rearview mirror. Does anyone have a clear photo I can use for reference? I don't have a volt meter or anything like that to figure it out.
Old 07-01-2014 | 10:38 AM
RonC5's Avatar
Rocket Scientist
There was no mirror outlet on my 08. I powered the V1 by running the power cord down the window post to the fuse block. Pulled power from the rear window fuse. If needed, I could kill the V1 power by hitting the window lock button. No reaching up to the detector for LEO's to notice.
Old 07-01-2014 | 12:52 PM
nfnsquared's Avatar
https://acurazine.com/forums/showpos...5&postcount=30
Old 07-01-2014 | 12:55 PM
AndrewA's Avatar
Everything you need in this thread
CLICK HERE FOR Invisicord Wiring to overhead power connector
Old 07-01-2014 | 08:33 PM
ShaneN.'s Avatar
Thanks for the replies, my invisicord is the shortest one they sell so I was hoping to go to the mirror. Any idea what length it takes to get to the moonroof switch? I got in that section of the car to unplug the bluetooth module and I was hoping I wouldn't have to ever go back in there, it was REALLY hard to pry anything in the gap to release the clip.
Old 07-01-2014 | 08:37 PM
ShaneN.'s Avatar
Also, what would this connector look like from dead on (if you were plugging the probes into it). It explains which one of the invisicord is ground and power but not where to plug it into. It appears like there is three wires there based on the other side.
Old 07-02-2014 | 08:29 PM
LaCostaRacer's Avatar
Shane- if you search this forum (possibly in electronics sub forum) you will get your answer. I don't remember the pin numbers to hook into, but got them from this forum many years ago. My detector has been running this way for 7 years now. I'll try to search and find the link. I would use Invisicord in your search string too.
Old 07-02-2014 | 08:35 PM
Here you go- 1/19/2008 in this thread- lots of pictures too!
https://acurazine.com/forums/showthr...ght=invisicord
Old 07-07-2014 | 11:49 PM
Invest in a multi-meter when working with Electronics. It will help you figure out ground and hot wires, etc.
ITSJESTER
17
12-06-2018 02:29 AM
chrisr
12-04-2015 02:17 AM
ITSJESTER
4G TL Photograph Gallery
10-13-2015 12:53 PM
Quick Reply: Invisicord for radar detector into rearview?
