Interior LED ideas
Old Jan 15, 2014 | 02:04 PM
DCrosby's Avatar
3rd Gear
Interior LED ideas
Hey everyone,
I'm helping my friend put in LED underglow under their dash, which I have done many times and has always been easy. Unfortunately, I usually went through a dashboard dimmer switch that came on automatically with the headlights. In a 2004 Acura TL however, it seems that tapping into the headlight system is going to be a huge pain since it is built into the steering wheel.
So my question is this: Where is an easy access 12V constant supply, and easy to access ground wire that can have the lighting easily tied into. Thanks!
Dillon
Note: This person is very cautious about me "taking things apart" which is why I am not about to take apart their steering wheel =P
Old Jan 15, 2014 | 02:05 PM
DCrosby's Avatar
3rd Gear
Also: I have thought about going into the cigerette lighters (either the one in front of the shifter, or the one in the center console). If this seems like a good idea, how hard is it to remove these and get to the wiring?
Old Jan 15, 2014 | 04:28 PM
tommyg55's Avatar
The one in the center console is pretty easy to get to you just have to unscrew the 2 screws in the arm rest and pull the silver trims off the sides of the center console to access the screws around the cup holder and pull that out and you're golden.
Old Jan 22, 2014 | 11:18 AM
DCrosby's Avatar
3rd Gear
When you say armrest, what do you mean? because her car doesn't have what I picture as an arm rest
Old Jan 22, 2014 | 01:09 PM
MarcoNorthPolo's Avatar
KCCO
It's the armrest in the middle. What were you picturing?
Old Jan 22, 2014 | 09:46 PM
tommyg55's Avatar
^the center console i guess if that makes more sense. In the bottom portion theres a rubber mat at the bottom and beneath that you'll see the screws.
Old Jan 22, 2014 | 10:58 PM
guitarplayer16's Avatar
Tap the positive wire to the parking light wire, which is located top left behind the driver dash cover (google pics for reference), and tap the ground to the steering column bolt.
That will give you what you want (turn on when you turn on headlights).
Old Jan 23, 2014 | 07:23 PM
Steven Bell's Avatar
I've got under dash lighting in the front and back. Check My Garage to see pictures.
Old Jan 25, 2014 | 07:46 AM
Nick216's Avatar
The Boss
my personal night club
Old Jan 27, 2014 | 11:47 AM
PowerSergNY's Avatar
Hey Nick, How did you do your set up? I just received my LED strips and I was planning on doing them tomorrow, Just Did clearing out my headlights last night and finishing sealing them today....
Are they on while you drive or only when the doors open?
thanks guys!
**** the easiest way possible, fingers are still numb from the dam headlights...lol ***
oo7spy
Jun 19, 2023 12:48 AM
Feb 25, 2020 09:57 AM
Sep 17, 2015 09:01 PM
Sep 17, 2015 10:16 AM
tiresmokinV8
Sep 15, 2015 09:10 PM
