Installion Of PIE X3
Do you think the installation of the PIE X3 will be difficult to do? The only thing i think i will have trouble with is powering the device. I dont really get how to do that. How much do you think a reputable shop should charge me for the installation of the PIE X3? I'm in southern california.
It's not difficult. You might need to take apart the car to get to the plug behind the head unit and to mount the brain and/or switch. Other than that, nothing too difficult. Mini add-a-circuit or just tap into the front power outlet to power it.
Where are your located in SoCal?
Here is my installation thread to help you get some ideas.
IMO, do some research and its an easy DIY. There are many threads with pictures and helpful info on here.
luniz97 had issues with getting his USA Spec to work. He's just a little bitter.
The USA Spec works well for many and his case is one of those instances that you get with every module.
Each product has advantages over the other. Its just personal preference... like many things.
How much do you think a shop should charge me for the installation of this? I really dont feel comfortable tapping in to get power for the PIE X3. If anyone knows any good shops in the Fullerton area it would be helpful.
Not worth paying someone to do the install. Read up on how members have installed theirs and just take it slow.
The mini add-a-circuit route will not require you to tap/splice any factory wires. I didn't unplug the battery during my install.
With time and patience, you can do it!
You can use fuse slot #32 in the fuse box in the driver's side well.
The mini add-a-circuit looks like this:
After hunting for it for a while, I found it at AutoZone.
gmahn
07-28-2006 05:50 PM
einsatz
10-06-2005 10:40 PM
Dantes
07-13-2001 08:51 PM
