Info on basslink
Old Apr 6, 2010 | 01:36 PM
TITANIUMTL's Avatar
Info on basslink
Looking for any info on infinity basslink or any other selfpowered subwoofer
Old Apr 11, 2010 | 10:30 PM
pohljm's Avatar
have one and like it
Old Apr 11, 2010 | 10:32 PM
csmeance's Avatar
its pretty straight forward, run the power wire from the front of the car to where-ever you are placing the basslink, and tap into the subwoofer wires for the signal
Old Apr 12, 2010 | 11:04 AM
Richard Weed's Avatar
Search. There are several threads with good info. I have one and like it. Be sure to hook up the remote volume control - better alternative to using the head unit subwoofer control.
Old Apr 12, 2010 | 03:55 PM
jdiszm's Avatar
basslink t
ive recently just purchased one and im trying to figure out how to get to the speaker wires or sub so i can run the signal to it also what about a remote wire or does this not need one? thanks for any help
Old Apr 13, 2010 | 08:41 AM
You don't need a remote wire if you connect directly to the stock subwoofer wires. You would need the remote wire if you used an LOC. An LOC isn't needed as the Basslink accepts high-level inputs. You need to drop the front of the panel in the trunk underneath the stock subwoofer by removing the small connectors - very easy.
Old Apr 21, 2010 | 02:24 PM
jdiszm's Avatar
Thanks i just realized that i didnt have this harness and bought one on ebay for 15$ cant wait to get it hooked up, i picked this up at my pawnshop for 50$ and it sounder pretty good when i tested it out. whats the best place to mount this and make it look nice because its actually wider than my trunks interior
Old Apr 23, 2010 | 11:13 AM
What do you mean by "its actually wider than my trunk's interior"? It should fit quite nicely in that space between the driver's side wheelwell and the back of the trunk, facing towards the inside of the trunk so you have access to the sound controls on the face of the unit.
Old Apr 25, 2010 | 03:47 PM
AcUrAoN20s's Avatar
8th Gear
any pics
Old May 2, 2010 | 11:30 AM
Haven't posted pics before - hopefully they're OK...
Old May 2, 2010 | 08:22 PM
oneway's Avatar
How does it sound? I was thinking about getting one.
Old May 2, 2010 | 09:40 PM
mglax13's Avatar
New shoes on my
big improvement over the stock sub?
Old May 2, 2010 | 10:04 PM
darcar's Avatar
When you tap into the subwoofer wires, are you using the Basslink instead of the stock sub, or are you using both?
Old May 3, 2010 | 06:35 AM
I think you can see larger versions of these pictures if you look at the photo album in my profile. I'm using both the stock sub and the basslink, though not sure the stock sub is making much of a contribution. The basslink is a great addition to fill out the sound and get a solid low end. Big improvement over the underpowered stock sub. The basslink has a smooth deep sound that works well with rock, pop or country, rather than a boomy sound that you might prefer with the rap or the hip hop (trying to talk like my dad).
TypeS860
Jan 10, 2026 11:11 AM
MrHeeltoe
20
Feb 23, 2023 01:54 PM
rcs86
Aug 2, 2016 06:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
