I need Navi Help
Old May 30, 2008 | 10:04 PM
gumby430's Avatar
I need Navi Help
Yeser day I got in the car and began to drive. i took a turn and the navi symb did not follow the road I was on. It actuall ran next to the raod bit not on and road. Just stayed off the raod and the more I drove the more off track it got. Not sure what happened of if this is common. Do I need to rest the navi or something. Is there a way to even reset it? Any ideas please. Thanks
Old May 30, 2008 | 10:15 PM
smsTL's Avatar
Sǝxy Timǝ in my
I know what you mean. When you set a destination and if you off track to a different road the Navi will think that you still on same road until you move farther apart. I think it is normal, it happens to me too.
Old May 30, 2008 | 10:16 PM
vinnier6's Avatar
i have had that happen before....normal
Old May 30, 2008 | 10:18 PM
gumby430's Avatar
Is there any way to reset the navi when this happens or will it correct it self when you shut down the car and come back later?
Old May 30, 2008 | 10:22 PM
JCL622's Avatar
A-spec steering wheel ftw
just depends where you are. most of the time it auto corrects...but if you live in an area where the roads are really close together it may never auto adjust, but you can always just move the cursor and set it to where you actually are and i think it remembers, not sure,
on a lighter note,...lol i found out that circle around the cursor? isn't just so it's easier to pin point that place better, it's also marked as the degree of error/freedom in approximation LOL;
made me chuckle.
Old May 30, 2008 | 10:24 PM
Will Y.'s Avatar
Registered but harmless
It should re-set as you drive-- mine will reset about 10-20 seconds after it goes awry.
Try hitting the "menu," then "map" buttons to see if that forces a reset if your car doesn't automatically reset its position.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
us285126
Oct 2, 2015 02:03 PM
jmaxima03
Sep 27, 2015 10:22 AM
Cgannotti
Sep 25, 2015 05:04 PM
